Single Test Run Reports don't work
Daniel Gheczy, geändert vor 12 Jahren.
Youngling Beiträge: 9 Beitrittsdatum: 11.11.09 Neueste Beiträge
I can't create single test run reports and am redirected to an error page, see first screenshot. In the second screenshot you can see the section of the tomcat window where I think the error occurs.
RE: Single Test Run Reports don't work
Hi Daniel,
thanks for the report. Can you please send us your tomcat logfiles to support@verit.de? Are other reports affected as well? Does the error persist after a tomcat restart?
Thanks for the log files. We will release the Version 2.3.3 later today that will contain a fix for this issue (KLAROS-587).
Hi Daniel,
the 2.3.3 Release is now available, can you please check if that solves your problem?
RE: Single Test Run Reports don't work (Antwort)
if installed 2.3.3 with a Postresql-DB now and everything seems to work so far. Thanks!!!
Greets Daniel
