RE: ENV/SUT can't be deleted
Torsten G, geändert vor 10 Jahren.
Youngling Beiträge: 4 Beitrittsdatum: 07.01.15 Neueste Beiträge
we have some TC-results deleted over Evaluate -  Test Runs - Delete this Test run.
If we also try to remove the ENV (or also SUT) we've got the result:
"Für dieses Objekt liegen bereits Testergebnisse vor, deshalb kann die Testumgebung (Testsystem) nicht gelöscht werden."
But, in ENV (or SUT)  all the tabs ("Test Case Results", "Test Suite Results", "Test Runs") are empty!
Environment: Klaros 4.2.6 EP with default database Apache Derby
Torsten G.
this is indeed a bug, the deleted flag of the test runs (which are still present in the database after deletion) is not honored in this case.
Tracked as bug KLAROS-2543 towards release 4.2.8.
Thanks for pointing that out!
Regads,
