RE: Valid configuration for Active-Directory?
Paul H, geändert vor 11 Jahren.
Youngling Beiträge: 3 Beitrittsdatum: 05.08.14 Neueste Beiträge
the user-manual (@ page 2) states:
Klaros-Testmanagement Enterprise Edition can authencate users against an external LDAP/Active Directory system which contains the passwords of the users
My environment is Klaros 4.2.3-Enterprise-Trial. I can't configure the AD-Login, the message is
The authentication with the LDAP server has failed
Can you give me an example for a valid AD-Config? Especially the value for "User Password Attribute" should be clarified for AD!
The other values I received from the admins:
  • Server Address mydomain.local
  • Server Port: 389
  • Bind DN: CN=Paul H,CN=Users,DC=mydomain,DC=local
  • Bind Credentials: MyPassword
  • User Search Attribute: samAccountName
  • User Name Attribute: cn
  • User Context DN: cn=Users,dc=mydomain,dc=local
  • User Object Classes: person,uidObject
  • User DN Prefix: samAccountName=
  • User DN Suffix: cn=Users,dc=mydomain,dc=local
  • Full Name Attribute: cn
  • Email Attribute: mail
Thank You!
Paul H.
Hi Paul,
The warning message "The authentication with the LDAP server has failed" can have a variety of causes. Could you please send the log files of Klaros-Testmanagement to support@verit.de? These files should contain a more descriptive error message that will help us configuring your LDAP/AD integration.
The section Important file locations in the documentation describes the location of the folders containing the log files.
Hi Paul,
your User DN Suffix is missing a leading comma as in: ,cn=Users,dc=mydomain,dc=local
The idea behind this is that the concatenation of <User DN Prefix><Result of User Name Attribute lookup using User Search Attribute><User DN Suffix> is giving you a valid DN to authenticate.
So from here I would say the following should work for you (leaving out unchanged fields):
User DN Prefix: cn=
User DN Suffix: ,cn=Users,dc=mydomain,dc=local
User Password Attribute: unicodePwd
User Password Attribute is the attribute containing the password(hash) in your AD.
AD (rightfully to hinder attacks) has the nasty habit to not deliver meaningful error messages for unsuccessful authentications so troubleshooting is really cumbersome.
Hope this helps, please let me know if this works for you or you need additional help.
Hi Torsten, Hi Fabian,
thank you about the missing-comma hint! Also I've changed the other attributes to your suggestions. But, no luck; the same ldap-error-message consists emoticon
Now I will ask the admins about the logs (like Fabian recommends). Hopefully they contain some AD messages.
Until then,
Paul
Hi Paul,
did you make any progress with your AD connection?
