Project Integration
Joby V A, geändert vor 11 Jahren.
Project Integration
While linking a testcase to a project in redmine, I am getting an error "There is no issue management system assigned to this project". But I have already assigned a redmine project and I can see that under "Assigned Issue Management Systems". I am using community edition. Please help.
Joby
RE: Project Integration
Hi Joby,
I tried to reproduce this against version 4.1.6 but was not able to encounter the situation you have described.
  • Did you make sure that the project is actually saved after assigning the issue management system?
  • Is the project you are editing is the one that is currently active?
  • Can you please state the version you are using?
Hope this helps.
Please see my answers.
Ans: Yes.
Ans: Yes
Ans: Community Edition 4.1.3 - Build 2206
Joby
Hi Joby,
I again tried to reproduce this against 4.1.3 and came to the same result that this is working as advertised.
As a reference for you I am adding screenshots of the relevant pages, maybe this helps pinning down the problem.
