XML import format - Klaros Test Management - Forum - Klaros-Testmanagement
XML import format
Alan Bowman, geändert vor 11 Jahren.
XML import format
Youngling Beiträge: 3 Beitrittsdatum: 03.02.14 Neueste Beiträge
I am trying to import test cases using the XML format, as specified in the manual. However, I keep getting an error "Unable to upload the file, due to validation error: Invalid Format", which doesn't provide a lot of clues as to where I am going wrong. I am a bit of a beginner with XML, but this seems to be the best way to import our existing tests. Is there a sample XML (or XSD) file that I could use as a starting point for the import file creation?
Alan
Alan
RE: XML import format
Hi Alan,
Welcome to the community.
It seems that this is missing from our documentation!
The XSD file may be found at http://www.klaros-testmanagement.com/files/klaros-testcases.xsd . I have added this to the documentation for the version 4.1.2.
Thanks for your interest in Klaros-Testmanagement. We're here to answer any further questions you might have.
Thank you for the schema file. However, it doesn't seem to have helped...
I have used the schema to auto-generate some valid XML. When I try to upload this I still get an "invalid format" error.
I have also tried exporting data from my test installation, stripping out all but the test cases. This fails validation against the schema, but successfully uploads. It doesn't create the tests I expect, but it's a useful datapoint.
I sort of expect that I can create an XML file which will import a series of testcases into the currently selected project. Have I understood correctly, or do I also need to define which project the cases will be added to?
Alan
Alan
RE: XML import format (Antwort)
Hi Alan,
The following (very) simple file will import a single test case consisting only of a name (also attached to this post):
Hopefully this will help you.
In order to import it into the project with the ID P1 in Klaros-Testmanagement the following curl command may be used:
of course replacing localhost with the hostname if not run on the computer running Klaros-Testmanagement.
I hope this helps.
<klaros:container xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" | |
xsi:schemaLocation="http://klaros-testmanagement.com/export-testcases-1.0" | |
xmlns:klaros="http://klaros-testmanagement.com/export-testcases-1.0"> | |
<klaros:testcases> | |
<klaros:testcase> | |
<klaros:shortname>Test Case Name</klaros:shortname> | |
</klaros:testcase> | |
</klaros:testcases> | |
</klaros:container> |
curl -v -T test-case-import.xml "http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xml?config=P00001" |
I hope this helps.
Excellent - that appears to have done the job. Thanks!
