RE: Select more than 1 test case
When you created a Job, is it possible to select more than one Test Case or Test Suite?
Angel Hidalgo
RE: Select more than 1 test case (Antwort)
Hi Angel,
no you can't, but you may nest several jobs as sub-jobs in a wrapping job.
The success and execution rate will be calculated on the rates of the corresponding sub-jobs.
Please also note that a job can be reused if results have to be taken again. The job keeps a list of all test runs which were executed for this job. Only the last test run will be taken into account for the success and progress rate calculation.
