RE: Import Test Cases from Excel - Klaros Test Management - Forum - Klaros-Testmanagement
I am testing how to import Test Cases from Excel. I have enabled cURL commands. I have created a .xlsx file like the example in the user manual. It is called Formato_TC.xlsx and it is located in: C:\Users\angel.hidalgo\Documents\Instaladores\Klaros>
I have typed the following expression:
C:\Users\angel.hidalgo\Documents\Instaladores\Klaros>curl -v -T Formato_TC.xlsx
'http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xlsx?confi
g=P000023'
But I got this:
* Protocol 'http not supported or disabled in libcurl
* Closing connection -1
curl: (1) Protocol 'http not supported or disabled in libcurl
I have tried again with this expression:
"http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xlsx?confi
g=P000023"
The result was:
* Adding handle: conn: 0x9031d0
* Adding handle: send: 0
* Adding handle: recv: 0
* - Conn 0 (0x9031d0) send_pipe: 1, recv_pipe: 0
* About to connect() to localhost port 18080 (#0)
* Trying 127.0.0.1...
> PUT /klaros-web/seam/resource/rest/import/testcase/xlsx?config=P000023 HTTP/1.
1
> User-Agent: curl/7.33.0
> Host: localhost:18080
> Accept: */*
> Content-Length: 11242
> Expect: 100-continue
< HTTP/1.1 100 Continue
< HTTP/1.1 404 No Encontrado
* Server Apache-Coyote/1.1 is not blacklisted
< Server: Apache-Coyote/1.1
< Set-Cookie: JSESSIONID=2F304E46DA5CD951DF9ACCAB63BD6658; Path=/klaros-web/; Ht
tpOnly
< Content-Language: es
< Content-Length: 1285
< Date: Fri, 31 Jan 2014 20:08:34 GMT
<html><head><title>Apache Tomcat/7.0.47 - Informe de Error</title><style><!--H1
{font-family:Tahoma,Arial,sans-serif;color:white;background-color
525D76;font-s
ize:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:
#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;bac
kground-color
525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif
;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;col
525D76;} P {font-family:Tahoma,Arial,sans-serif;backg
round:white;color:black;font-size:12px;}A {color : black;}A.name {color : black;
}HR {color : #525D76;}--></style> </head><body><h1>Estado HTTP 404 - Could not f
ind resource for relative : /import/testcase/xlsx of full path: http://localhost
:18080/klaros-web/seam/resource/rest/import/testcase/xlsx?config=P000023</h1><HR
size="1" noshade="noshade"><p><b>type</b> Informe de estado</p><p><b>mensaje</b
> <u>Could not find resource for relative : /import/testcase/xlsx of full path:
http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xlsx?config
=P000023</u></p><p><b>descripci+¦n</b> <u>El recurso requerido no est+í disponib
le.</u></p><HR size="1" noshade="noshade"><h3>Apache Tomcat/7.0.47</h3></body></
html>* Connection #0 to host localhost left intact
After that I reviewed the P000023, and the Test Case was not imported. I don't know what the problem is??? Please help me. Give more information or examples about it.
PD: I attached Formato_TC.xlsx file and logs of cmd
Thanks in advance
Angel Hidalgo
g=P000023'
But I got this:
g=P000023"
The result was:
1
> Accept: */*
tpOnly
kground-color
Thanks in advance
Angel Hidalgo
Hi Angel,
I think there is a typo in your URL, you should use http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xls?config=P000023 instead (xslx -> xsl).
Actually my excel file was done in Excel 2010, for that reason I have .xlsx extension.
I have changed the extension file to .xls. After that I have typed this command:
C:\Users\angel.hidalgo\Documents\Instaladores\Klaros>curl -v -T Formato_TC.xls "http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xls?config=P000023"
I got this:
Tomcat result:
2014-01-09 08:34:49: ERROR, de.verit.klaros.web.servlet.importer.testcase.XMLTestCaseImportServlet Authentication error - a username and password is required
CMD result:
* Adding handle: conn: 0xb23140
* - Conn 0 (0xb23140) send_pipe: 1, recv_pipe: 0
> PUT /klaros-web/seam/resource/rest/import/testcase/xls?config=P000023 HTTP/1.1
> Accept: */*
> Content-Length: 30208
< HTTP/1.1 400 Petición incorrecta
< Set-Cookie: JSESSIONID=4858CD961A09BB45629E96D8964EDE2C; Path=/klaros-web/; Ht
tpOnly
< Content-Type: */*
< Transfer-Encoding: chunked
< Date: Thu, 09 Jan 2014 13:34:49 GMT
< Connection: close
* we are done reading and this is set to close, stop send
* Closing connection 0
It asked for an authentication, but I don't understand because the project is opened.
Please help me.
Thanks in advance,
Angel Hidalgo
I got this:
Tomcat result:
CMD result:
> Accept: */*
tpOnly
< Content-Type: */*
< Connection: close
Please help me.
Thanks in advance,
Angel Hidalgo
RE: Import Test Cases from Excel (Antwort)
Hi Angel,
Your project is secured against unauthenticated access in your project settings.
You need to provide your username and password to authenticate at the import REST interface. Please refer to http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Import-Export.html#User-Manual.Import-Export.TestResultImport for an example.
Hi again Torsten,
Thanks for your support.
I disabled Authentication requiered for import option. Then I typed
But now I got this:
* Adding handle: conn: 0x8c3140
* - Conn 0 (0x8c3140) send_pipe: 1, recv_pipe: 0
> Accept: */*
< HTTP/1.1 500 Error Interno del Servidor
< Set-Cookie: JSESSIONID=5C7FE1401F2FF88B89ED57BDF3942A3F; Path=/klaros-web/; Ht
tpOnly
< Content-Type: */*
< Date: Thu, 09 Jan 2014 14:17:49 GMT
< Connection: close
Import action failed: de.verit.klaros.exception.KlarosUnexpectedRuntimeException
: Unexpected runtime exception: No system user present in the database - unable
to import* we are done reading and this is set to close, stop send
Again I got problems. Do you know why does it happen?
Thanks in advance.
Angel Hidalgo
But now I got this:
> Accept: */*
tpOnly
< Content-Type: */*
< Connection: close
Thanks in advance.
Angel Hidalgo
You have deleted or disabled the 'system' user account which is the default creator of the imported test cases if you do not provide the credentials of a valid user via username/password attributes.
I am stuck. My current configuration is showed on the picture attached <System configuration.png>
My user name is a_hidalgo
My password is admin
I saw the help in http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Import-Export.TestResultImport.html
Following the example, I have
C:\Users\angel.hidalgo\Documents\Instaladores\Klaros>curl -v -T Formato_TC.xls "http://localhost:18080/klaros-web/seam/resource/rest/import/testcase/xls?config=P000023&username=a_hidalgo&password=admin"
I got this:
No project configuration found for P000023* Closing connection 0
But my project is opened. what do I need to do??
Thanks in advance,
Angel Hidalgo
I got this:
Thanks in advance,
Angel Hidalgo
Your project id is P00023 - not P000023.
Ohhhhh, so sorry. I changed it and it got this result:
We are completely uploaded and fine.
It is great. Thanks for your patience
Now I have 3 more questions:
1. How to update the project to see the Test Cases imported?
2. Is it posible to import test cases in Klaros Community Edition?
3. Is it necessary to install Jenkins/Hudson Plugin for Klaros-Testmanagement?
Thanks in advance for your answers.
Angel Hidalgo
Angel Hidalgo
Jedi Council Member Beiträge: 770 Beitrittsdatum: 12.02.09 Neueste BeiträgeIt is great. Thanks for your patience
Good to hear, you're welcome.
They are automatically available and should appear at the next page render of the project.
Yes.
No. You use that only if you intend to have Jenkins automatically push test case results for the tests it executed.
Thank you Torsten, but I have still problems updating Test Case, which was imported from Excel. I can't see it into the project.
I did that, but I didn't get good results. Do I have to set any additional parameter in the project??
Thanks in advance.
Thanks in advance.
Possibly nothing was importing as the document or the format may not have been properly recognized.
I added a working sample in Excel 2003 for your reference.
You are right Torsten,
I have uploaded your file and it works.
After that I created a new excel file with the same characteristics than yours, but it doesn't work. I guess you need a special settings in the file, which are not specified in user manual.
I attached my file.
PD: I just note one difference between them. My file is weighting 29.5KB and yours is weighting 7.5 KB, but the content is the same. I don't understand it.
Angel Hidalgo
I attached my file.
Angel Hidalgo
Now that was an interesting one to debug ...
Your Excel-Sheet contains the word Step instead of Step (notice the trailing blank) at the position A:25.
This leads to ignoring this complete worksheet as this word is the detection trigger.
I opened and implemented Enhancement KLAROS-2112 to trim whitespace here just in case that this will happen again to others.
Interesting enough, this trailing blank seems only to appear with stylesheets written by Excel itself. After loading and saving your example with LibreOffice the cell A:25 was automatically trimmed and written in a parseable format.
Removing the trailing blank should get you on track again.
Have a nice weekend,
You are absolutely right Torsten. Thank you so much.
I deleted that additional space after <Step> and it works.
But I guess, this issue should be improved, because when people create a new file in Excel, they could add this space while they write.
Additionaly, in the user manual you don't have enough information to import test cases succesfully from excel. Without your help I hadn't got good results. I recommend to you to include more information about it.
Also in user menu in curl command to import Test Cases you are using <'>, but I got errors. I typed <"> and it works well. You should change it.
I am going to test more functionalities of Klaros because we are planning to use it in our enterprise. If I find more problems I will write to you. I hope your support.
Thanks for everything. Have a nice weekend too.
Angel Hidalgo
Angel Hidalgo
The manual has been updated with additional information regarding test case import from Excel.
Thanks for the pointer!
Yes, I noticed that. It's excellent.
Thanks for including my comments.
Angel Hidalgo
Angel Hidalgo
Hi
Again, I got troubles importing test cases from excel. I got this message at the end of importing:
[Aborting import of sheet Formato_TC due to missing definition of user defined property Category, Aborting import of sheet Formato_TC due to missing definitionof user defined property Cycle]* Closing connection 0
Please help me.
Thanks in advance
Angel Hidalgo
Please help me.
Thanks in advance
Angel Hidalgo
I have found the problem. When I want to add <Custom Properties> like in <User manual>, Cycle and Category, I get the error. I gues this is a bug of you.
Angel Hidalgo
Angel Hidalgo
Typing this on my phone so please excuse the brevity.
To import a sheet containing custom properties these have to be defined under the name on the left hand side (e.g. Color) in the project you will like to import them into.
If you leave them out this should work out of the box. If you add them in your sheet make sure they are defined in the project. This is what the error message above is trying to tell you.
So I think this works as expected.
Thanks Torsten,
I included custom property in <user defined> tab. It is working now.
Angel
Angel
