Klaros-Testmanagement 3.8.6 released
We are pleased to announce the release of Klaros-Testmanagement version 3.8.6.
The 3.8 release adds official support for Bugzilla 4.4, Jira 5.2 as well as MS SQL Server and Internet Explorer 10.
The 3.8.6 maintenance release fixes some minor bugs.
Version 3.8.6 - 2014-01-13:
[KLAROS-2101] - Unable to select system under test when linking issues
[KLAROS-2085] - Unable to access test run report when the user full name is empty
[KLAROS-2061] - Prior deleted attachments may inhibit the deletion of the same attachment in some cases
[KLAROS-2057] - An error occurs when a new object is created but not saved, the global select button is clicked, the bulk duplicate button is clicked and drop changes is clicked in the popup
[KLAROS-2056] - Export of category information may fail due to nested dependency loop
[KLAROS-2112] - The XLS test case importer should not enforce trimmed key-field values
Version 3.8.5 - 2013-12-03:
[KLAROS-2039] - Test runner dialog overlap when editing last test step
[KLAROS-2037] - Start test case dialog does not properly size for large descriptions
[KLAROS-2034] - Moving freshly cloned objects into newly created categories may lead to an error in categorization
[KLAROS-2009] - Enum property resolution fails during import of test environment enumeration properties
[KLAROS-2008] - Setting a very large default table size breaks some dialog layouts
[KLAROS-1960] - Custom enumeration property values are not properly resolved in the model API
[KLAROS-2033] - Improve overall performance by lazily creating the uuid of a persistent object
Version 3.8.4 - 2013-11-08:
[KLAROS-2000] - Altered objects still displayed in list even when a different category is selected
[KLAROS-1999] - Test case result summary field is not saved properly in the test runner
[KLAROS-1998] - Changing filter options with unsaved changes leads to errors in saving
[KLAROS-1996] - Exception while saving a test suite after removing a test case
[KLAROS-1994] - Failure resolving category nodes in the model API: java.lang.ClassCastException: java.util.UUID cannot be cast to java.lang.String
[KLAROS-1985] - Error 'The report could not be created: No matching entries for the given parameters could be found.' while rendering the builtin Test Run History report, System Under Test report and Test Environment report
Version 3.8.3 - 2013-10-20:
[KLAROS-1980] - When adding multiple search filter parameters for the same field only the first one is recognized
[KLAROS-1979] - Attachment references are not properly handled during XML project imports
[KLAROS-1963] - KlarosTestCaseResult delivers TestCaseStepResult instances instead of the documented KlarosTestCaseStepResult model class
[KLAROS-1962] - Pending test runs must not be listed on the evaluate test runs page
[KLAROS-1959] - Missing Test Result verdict in the Community Edition
[KLAROS-1949] - Disabled administrator accounts are able to upgrade the database
[KLAROS-1807] - Default enum property field not properly transferred when copying test cases between projects
[KLAROS-1976] - Make categorization information available in the report API
[KLAROS-1969] - Move common methods to the IKlarosNamedEntity interface
[KLAROS-1957] - Avoid large search result sets for LDAP authentication
Version 3.8.2 - 2013-09-12:
[KLAROS-1955] - Creating an issue leads to an error
[KLAROS-1954] - Install fails on linux systems due to missing resource
Version 3.8.1 - 2013-09-10:
[KLAROS-1952] - Managers can not create new users
[KLAROS-1951] - Deleting a category can cause errors when loading test cases
[KLAROS-1950] - Users in the role test manager cannot create report templates
[KLAROS-1948] - The problem report page does not correctly handle the case where no user has yet been authenticated
[KLAROS-1946] - Cloning test cases or test suites in a project with deleted property definitions leads to an exception
[KLAROS-1945] - Overflow error in server uptime calculation
[KLAROS-1929] - Changed LDAP Preferences are only valid after a reboot
[KLAROS-1927] - Unable to send email to Microsoft Exchange when a username/password is specified in the email configuration but the server does not support this
[KLAROS-1926] - Unable to automatically create a user account for the initial LDAP login
[KLAROS-1921] - Removing test cases from test suites may cause problems while deleting a project
[KLAROS-1943] - Allow to specify different DN user name attribute and user search attribute in the LDAP authenticator for complex LDAP instances
[KLAROS-1937] - Disable generate jobs button when no elements are selected
[KLAROS-1936] - Add job information to the test run API model
[KLAROS-1935] - When authenticating over LDAP avoid sending empty passwords as some Active Directory installations do not seem to reject authentications properly
[KLAROS-1934] - Allow to filter enabled / disabled users
[KLAROS-1932] - Add success rate information to the job model API
[KLAROS-1931] - Extend the project configuration model to list the available jobs
[KLAROS-1930] - Allow to check LDAP credentials interactively while configuring the LDAP access
[KLAROS-1928] - Extend the report model API to include the external issue id
[KLAROS-1925] - Misleading log warning: Attempt to close session after it has already been closed. Please review your code for proper session management.
[KLAROS-1924] - Add test case step information to the test case step result model
[KLAROS-1920] - More detailed error message while saving users
Version 3.8.0 - 2013-07-29:
New Features:
[KLAROS-1906] - Add support for Jira 5.2
[KLAROS-1905] - Add support for Bugzilla 4.4
[KLAROS-1902] - Allow to bulk add test cases to existing test suites
[KLAROS-1894] - Add support for Internet Explorer 10
[KLAROS-1877] - Add support for MS SQL Server
[KLAROS-1919] - Choosing an item in the user test run history suggests switching to a different project even if the test run belongs to same project
[KLAROS-1916] - Possible error while loading enumeration properties
[KLAROS-1908] - Full-text search results are not closed properly
[KLAROS-1904] - Permalink pages not accessible under certain conditions
[KLAROS-1903] - Do not try to sync user information to the content management system when no user login is present
[KLAROS-1900] - Error during database upgrade to version 3.7.9
[KLAROS-1898] - IE renders the invisible row selector entries in the ID columns of tables
[KLAROS-1897] - The execute popup sometimes displays when a test case or test suite is not executable
[KLAROS-1896] - The Execute test suite dialog must have a fixed paging size for the listed test cases
[KLAROS-1892] - Avoid startup problems while retrieving garbled version information
[KLAROS-1886] - The test suite overview report does not render correctly using a Derby database
[KLAROS-1885] - Jobs are not always correctly updated after execution
[KLAROS-1917] - Document how to support UTF-8 character sets in MySQL database servers
[KLAROS-1909] - Disable the predefined initial version comment for test cases and test suites
[KLAROS-1907] - Automatically set the windows service JVM memory parameters during startup
[KLAROS-1899] - Restrict the project locked icon to the administrator role
[KLAROS-1893] - Improved rendering speed on list pages
[KLAROS-1890] - The latest success rate dashboard report should ignore test case results with verdict skipped
[KLAROS-1888] - Do not suggest to select a project if there already is an auto selected project present
