RE: Bugzilla issue/question: custom field support
Dutch Buckholz, geändert vor 13 Jahren.
Youngling Beiträge: 10 Beitrittsdatum: 18.04.12 Neueste Beiträge
Hi all,
Suggestions?
Dutch
Edit to include more data:
<bz:cf_browser>
<Seq>
<li>---</li>
<li>IE</li>
<li>Firefox</li>
<li>Safari</li>
<li>Chrome</li>
</Seq>
</bz:cf_browser>
<bz:cf_casetype>
<Seq>
<li>Bug</li>
<li>Enhancement</li>
<li>Task</li>
<li>Doc</li>
<li>Prod Incident</li>
<li>---</li>
</Seq>
</bz:cf_casetype>
RE: Bugzilla issue/question: custom field support (Antwort)
Hi Dutch,
Thanks again,
Dutch
Thanks for your patience - so many feature requests, so little time emoticon
Philippe A Couvignou, geändert vor 13 Jahren.
Youngling Beitrag: 1 Beitrittsdatum: 30.11.12 Neueste Beiträge
Thanks.
