Test suite resume / delete
Dom Barker, modified 11 Years ago.
Youngling Posts: 5 Join Date: 9/6/12 Recent Posts
Hi Guys,
We are running:
Klaros 3.6.10 - Build 143 (2012-08-27 10:26:45)
When we:
-Create a test suite,
-Add cases to it,
-Start the test suite run,
-Get 1/2 way through
-Pause the run
-Resume the run
-Then remove one of the test cases from the suite
We get an out of bounds exception when we try to delete it.
Log is attached.
Can you let me know if this is an issue or if its something that I am doing daft (normally we wouldn't remove a case after starting a suite, but we had a stale test in it)
Kind regards
Dom
RE: Test suite resume / delete (Answer)
Hi Dom,
this is definitely an issue on our side. I raised issue KLAROS-1722 to track this.
To remedy this you can insert a test case at the deleted position, which you may skip during execution of the resumed test suite execution.
Setting the test case state of the corresponding test case to 'skip' should work as well.
Thanks for letting us know!
Hi Torsten
Thanks for the workaround and letting me know.
Dom
Fixed with version 3.6.11.
