Issues by Test Case - Klaros Test Management - Forum - Klaros Test Management
Issues by Test Case
Dom Barker, modified 11 Years ago.
Issues by Test Case
Youngling Posts: 5 Join Date: 9/6/12 Recent Posts
Hi All,
First post so apologies if this has been repeated elsewhere.
Issue:
Issues by Test Case - Clicking on ID results in
Page not found
The page you were trying to access doesn't exist or has been removed.
We are running:
Klaros 3.6.10 - Build 143 (2012-08-27 10:26:45)
Redmine 1.4.3.stable (MySQL)
Mylyn Connector plugin2.7.6.stable
The link for the ID points to:
http://redmine/redmine/issues/show/12345
It needs to be:
http://redmine/redmine/issues/12345
Let me know if you need anything else
Kind regards
Issue:
Page not found
We are running:
It needs to be:
Kind regards
RE: Issues by Test Case
Hi Dom,
thanks a lot for reporting this.
Looks like the support for the 'show' path fragment has been dropped somewhere in between Redmine 1.0 and 1.4 releases. The URL you are proposing works for both versions.
Tracked as KLAROS-1720 and fixed towards 3.6.11 and 3.7.0.
Thanks for letting me know, I will get 3.7.0 > put on when it is released.
If I find anything else I will log it here.
Dom
Dom
Fixed with 3.6.11. 3.7 is out as well.
