Importing data causes error - Klaros Test Management - Forum - Klaros Test Management
Thomas Reimer, modified 11 Years ago.
Hi everyone,
I recently set up a new Klaros 3.6.1 server on maschine B and tried to import the project data from the production server A running a Klaros 3.4.6. For this I used an exported project backup xml file. The import failes with the following error messages on the status bar:
Fehler beim Importieren des Projektes: xyz1 : P00001
Fehler beim Importieren des Projektes: xyz2 : P00002
Fehler beim Importieren des Projektes: xyzn : P0000n
The following exception is thrown:
The error appears both with the out-of-the-box DerbyDB and a clean mysql klaros database.
Thomas
2012-06-05 14:37:50: ERROR, org.jboss.seam.transaction.SynchronizationRegistry, http-18080-5 Exception processing transaction Synchronization after completion | |
org.springframework.dao.InvalidDataAccessApiUsageException: object references an unsaved transient instance - save the transient instance before flushing: de.verit.klaros.core.persistent.TestCaseStepFragment; nested exception is org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance before flushing: de.verit.klaros.core.persistent.TestCaseStepFragment | |
at org.springframework.orm.hibernate3.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:671) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at org.springframework.orm.hibernate3.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:412) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:411) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at org.springframework.orm.hibernate3.HibernateTemplate.executeWithNativeSession(HibernateTemplate.java:374) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at org.springframework.orm.hibernate3.HibernateTemplate.get(HibernateTemplate.java:512) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at org.springframework.orm.hibernate3.HibernateTemplate.get(HibernateTemplate.java:506) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at de.verit.klaros.core.dao.hibernate.HibernateDAO.get(HibernateDAO.java:152) ~[klaros-migration-3.6.1.jar:3.6.1] | |
at de.verit.klaros.core.dao.hibernate.HibernateDAO.get(HibernateDAO.java:49) ~[klaros-migration-3.6.1.jar:3.6.1] | |
at de.verit.klaros.web.service.categorization.BaseCategorizationService.getCategoryTreeSelection(BaseCategorizationService.java:117) ~[BaseCategorizationService.class:na] | |
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.6.0_31] | |
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) ~[na:1.6.0_31] | |
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) ~[na:1.6.0_31] | |
at java.lang.reflect.Method.invoke(Method.java:597) ~[na:1.6.0_31] | |
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:77) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:185) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:103) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at de.verit.klaros.web.service.categorization.SUTCategorizationService_$$_javassist_seam_56.getCategoryTreeSelection(SUTCategorizationService_$$_javassist_seam_56.java) ~[SUTCategorizationService.class:na] | |
at de.verit.klaros.web.beans.base.BaseCategoryBean.loadSUTCategoryDropDown(BaseCategoryBean.java:1089) ~[BaseCategoryBean.class:na] | |
at de.verit.klaros.web.beans.pages.define.AssignSUTToCategoryBean.loadCategoryTree_aroundBody0(AssignSUTToCategoryBean.java:148) ~[AssignSUTToCategoryBean.class:na] | |
at de.verit.klaros.web.beans.pages.define.AssignSUTToCategoryBean.loadCategoryTree_aroundBody1$advice(AssignSUTToCategoryBean.java:85) ~[AssignSUTToCategoryBean.class:na] | |
at de.verit.klaros.web.beans.pages.define.AssignSUTToCategoryBean.loadCategoryTree(AssignSUTToCategoryBean.java:1) ~[AssignSUTToCategoryBean.class:na] | |
at de.verit.klaros.web.beans.base.BaseCategoryBean.categorySelectionListener(BaseCategoryBean.java:1158) ~[BaseCategoryBean.class:na] | |
at org.jboss.seam.core.SynchronizationInterceptor.aroundInvoke(SynchronizationInterceptor.java:32) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at de.verit.klaros.web.beans.pages.define.AssignSUTToCategoryBean_$$_javassist_seam_67.categorySelectionListener(AssignSUTToCategoryBean_$$_javassist_seam_67.java) ~[AssignSUTToCategoryBean.class:na] | |
at org.jboss.seam.util.Reflections.invokeAndWrap(Reflections.java:144) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.Component.callComponentMethod(Component.java:2275) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.core.Events.raiseEvent(Events.java:85) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.async.AsynchronousEvent$1.process(AsynchronousEvent.java:33) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.async.Asynchronous$ContextualAsynchronousRequest.run(Asynchronous.java:80) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.async.AsynchronousEvent.execute(AsynchronousEvent.java:27) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.async.TransactionCompletionEvent.afterCompletion(TransactionCompletionEvent.java:20) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.transaction.SynchronizationRegistry.afterTransactionCompletion(SynchronizationRegistry.java:42) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.transaction.SeSynchronizations.afterTransactionCommit(SeSynchronizations.java:37) [jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.ioc.spring.SpringTransaction.commit(SpringTransaction.java:130) [jboss-seam-ioc-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.jsf.SeamPhaseListener.commitOrRollback(SeamPhaseListener.java:612) [jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.jsf.SeamPhaseListener.commitOrRollback(SeamPhaseListener.java:603) [jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.jsf.SeamPhaseListener.handleTransactionsAfterPhase(SeamPhaseListener.java:344) [jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.jsf.SeamPhaseListener.afterServletPhase(SeamPhaseListener.java:244) [jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at org.jboss.seam.jsf.SeamPhaseListener.afterPhase(SeamPhaseListener.java:195) [jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at com.sun.faces.lifecycle.Phase.handleAfterPhase(Phase.java:175) [jsf-impl-1.2_14.jar:1.2_14-b01-FCS] | |
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:114) [jsf-impl-1.2_14.jar:1.2_14-b01-FCS] | |
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:139) [jsf-impl-1.2_14.jar:1.2_14-b01-FCS] | |
at de.verit.klaros.web.beans.application.lifecycle.LifecycleImpl.render(LifecycleImpl.java:125) [LifecycleImpl.class:na] | |
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:19) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:132) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:74) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:31) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.common.standard.PathDispatcherServer.service(PathDispatcherServer.java:24) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:16) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:23) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:53) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:26) [icefaces-1.8.2-1.jar:na] | |
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:131) [icefaces-1.8.2-1.jar:na] | |
at javax.servlet.http.HttpServlet.service(HttpServlet.java) [servlet-api.jar:na] | |
at de.verit.klaros.web.servlet.ExceptionHandlingPersistentFacesServlet.service(ExceptionHandlingPersistentFacesServlet.java:47) [ExceptionHandlingPersistentFacesServlet.class:na] | |
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:56) [icefaces-1.8.2-1.jar:na] | |
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java) [catalina.jar:6.0.32] | |
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:197) [javamelody-core-1.37.0.jar:1.37.0] | |
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:171) [javamelody-core-1.37.0.jar:1.37.0] | |
at de.verit.klaros.web.beans.interceptor.TimingFilter.doFilter(TimingFilter.java:48) [TimingFilter.class:na] | |
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java) [catalina.jar:6.0.32] | |
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java) [catalina.jar:6.0.32] | |
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java) [tomcat-coyote.jar:6.0.32] | |
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java) [tomcat-coyote.jar:6.0.32] | |
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java) [tomcat-coyote.jar:6.0.32] | |
at java.lang.Thread.run(Thread.java:662) [na:1.6.0_31] | |
Caused by: org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance before flushing: de.verit.klaros.core.persistent.TestCaseStepFragment | |
at org.hibernate.engine.ForeignKeys.getEntityIdentifierIfNotUnsaved(ForeignKeys.java:243) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.type.EntityType.getIdentifier(EntityType.java:456) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.type.ManyToOneType.nullSafeSet(ManyToOneType.java:121) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.persister.collection.AbstractCollectionPersister.writeElement(AbstractCollectionPersister.java:815) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.persister.collection.AbstractCollectionPersister.recreate(AbstractCollectionPersister.java:1203) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.action.CollectionRecreateAction.execute(CollectionRecreateAction.java:58) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:273) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:265) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:188) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.event.def.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:321) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.event.def.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:51) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1216) ~[hibernate-core-3.6.10.Final.jar:3.6.10.Final] | |
at org.hibernate.search.impl.FullTextSessionImpl.flush(FullTextSessionImpl.java:388) ~[hibernate-search-3.3.0.Final.jar:3.3.0.Final] | |
at sun.reflect.GeneratedMethodAccessor556.invoke(Unknown Source) ~[na:na] | |
at org.jboss.seam.persistence.HibernateSessionInvocationHandler.invoke(HibernateSessionInvocationHandler.java:82) ~[jboss-seam-2.2.2.Final.jar:2.2.2.Final] | |
at $Proxy89.flush(Unknown Source) ~[na:na] | |
at org.jboss.seam.ioc.spring.SeamManagedSessionFactoryBean$SeamManagedSessionHandler.invoke(SeamManagedSessionFactoryBean.java:300) ~[jboss-seam-ioc-2.2.2.Final.jar:2.2.2.Final] | |
at $Proxy90.flush(Unknown Source) ~[na:na] | |
at org.springframework.orm.hibernate3.HibernateAccessor.flushIfNecessary(HibernateAccessor.java:390) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:407) ~[spring-orm-3.1.1.RELEASE.jar:3.1.1.RELEASE] | |
... 105 common frames omitted |
Thomas
RE: Importing data causes error
Hi Thomas,
is it possible to send the export file for analysis to support@verit.de ?
If you have concerns about sending internal data - the XSLT script found here should be able to hide all sensitive information in the dump.
Please note that the import export feature is currently quite limited in functionality and omits some information during the process (Most notably users).
We currently recommend using database backup/restore methods for production use (e.g. mysqldump).
This issue (KLAROS-1656) is supposed to be fixed with the 3.6.5 release.
Thanks for reporting!
seems to be working properly now in the recent release. Thanks for the quick solving of the problem.
Thomas
Thomas
