Can I use an existing web server installation? - Klaros Test Management - Forum - Klaros Test Management
Christoph Kuner, modified 13 Years ago.
Youngling Posts: 6 Join Date: 11/3/10 Recent Posts
Is it possible to install the Klaros Testmanagement System on top of an existing Apache Server installation?
Do I have to use the Apache Tomcat installation that comes with the installation package?
RE: Can I use an existing web server installation? (Answer)
Hi Christoph,
the tomcat installation is needed in any case as it provides the web application container for the klaros-web.war to run in.
If you want to direct the traffic through your existing apache server you may provide a transparent reverse proxy mapping like shown below.
ProxyPass /klaros-web/ http://dev.verit.de:18080/klaros-web/
ProxyPassReverse /klaros-web/ http://dev.verit.de:18080/klaros-web/
# Restrict access to klaros-web
<Location "/klaros-web/">
Order Deny,Allow
Deny from all
Allow from 127.0.0.1 10.140
</Location>
Be sure to set the application URL in the general settings in this case. This also described in the manual here.
Hope this helps.
Order Deny,Allow
Deny from all
</Location>
Hope this helps.
