Import/Export test cases from excel - Klaros Test Management - Forum - Klaros Test Management
Hanaa Saroar, modified 10 Years ago.
Youngling Posts: 2 Join Date: 8/9/10 Recent Posts
Hi Hanaa,
Use XML:
Use a common excel format:
What do you think?
Use XML:
What do you think?
Deepak Vishwakarma, modified 13 Years ago.
Youngling Post: 1 Join Date: 11/16/10 Recent Posts
Hello Tarsten,
Hello Deepak,
Hope this helps, regards
Mike Thirdy, modified 11 Years ago.
Youngling Post: 1 Join Date: 1/9/13 Recent PostsTorsten Stolpmann:
Thanks in advance,
Mike
Jedi Council Member Posts: 755 Join Date: 2/12/09 Recent PostsTobias Wagner, modified 3 Years ago.
Youngling Post: 1 Join Date: 2/25/21 Recent Posts
Hey community,
Thanks and best regards
Tobias Wagner
Tobias Wagner
Hello Tobias,
thank you for your feedback!
There are alternatives available, but the existing code is not suitable for an export scenario.
