Generate Job PDF Overview Report - Klaros Test Management - Forum - Klaros Test Management
Thomas Pich, modified 7 Years ago.
Youngling Posts: 5 Join Date: 10/19/16 Recent Posts
I setup a fresh System and defined Project, some Requirements, ENV, SUT and some Test Cases. I executed a Test Case and can see the results. When I request a Job Detail Report 1.0, I get a nice PDF-report. When I request a Job PDF Overview Report 1.0 it times out with a "com.lowagie.text.ExceptionConverter: Connection timed out: connect"-exception in klaros.log. The Job Excel Overview Report works fine as well. Btw. I use the 30-day eval-licence.
Thanks for your fast answer a short while ago.
Thomas
Thomas
RE: Generate Job PDF Overview Report (Answer)
Hi Thomas,
I suspect that you are located behind a firewall which is blocking HTTP access to the outside.
The report in question is referencing an external image located on our servers (Namely: http://www.klaros-testmanagement.com/files/scripting/Klaros+logo.png).
You may either remove this image from the template of the report or add HTTP-Proxy settings which allow Klaros to connect to the outside via HTTP. You can find the Proxy settings under Configure / Integration / Network.
Hope this helps, please let me know if this worked for you.
yes, I'm located behind a proxy and my network settings were not correct. But if I use the ProxyHost- and ProxyPort-field and I test is with "Test proxy settings" I get a "Cannot connect to proxy at host:null"-message and the PDF-generation failed too. Maybe you can check this again.
The work around is to set the proxy settings in setenv.bat and restart the server. That works for me:
Thank you!
Thomas
set CATALINA_OPTS=%CATALINA_OPTS% -XX:MaxPermSize=192m -Xms256m -Xmx768m -Dhttp.proxyHost=10.101.0.32 -Dhttp.proxyPort=8080 |
Thomas
Hi Thomas,
thanks for the heads-up! This is indeed a regression which now has been fixed under KLAROS-3104 towards the next release.
