Problem in renderResponse: javax.faces.FacesException: javax.el.ELException
Anders Forslund, modified 10 Years ago.
Youngling Posts: 12 Join Date: 1/27/10 Recent Posts
Hi!
I can redo it when i do following:
Click on making new testcase.
Dont write anything down, but click on execute.
Then press Define again.
Kaboom. Now the only solution is to log in again.
Anders Forslund
Stac:
Problem in renderResponse: javax.faces.FacesException: javax.el.ELException: /pages/subviews/subviewTestCases.jspx @341,82 value="#{testCaseHandler.testCases}": Error reading 'testCases' on type de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_47
at com.icesoft.faces.application.D2DViewHandler.renderView(D2DViewHandler.java:159)
at de.verit.klaros.web.beans.application.LifecycleImpl.render(LifecycleImpl.java:56)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
Caused by: Problem in renderResponse: javax.faces.FacesException: javax.el.ELException: /pages/subviews/subviewTestCases.jspx @341,82 value="#{testCaseHandler.testCases}": Error reading 'testCases' on type de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_47
at com.icesoft.faces.component.panelseries.UISeries.getValue(UISeries.java:576)
at com.icesoft.faces.component.panelseries.UISeries.getDataModel(UISeries.java:357)
at com.icesoft.faces.component.panelseries.UISeries.processCurrentRowData(UISeries.java:144)
at com.icesoft.faces.component.panelseries.UISeries.setRowIndex(UISeries.java:136)
at com.icesoft.faces.component.datapaginator.DataPaginatorRenderer.encodeBegin(DataPaginatorRenderer.java:217)
at javax.faces.component.UIComponentBase.encodeBegin(UIComponentBase.java:808)
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:356)
at com.icesoft.faces.renderkit.dom_html_basic.GroupRenderer.encodeChildren(GroupRenderer.java:96)
at javax.faces.component.UIComponentBase.encodeChildren(UIComponentBase.java:832)
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:358)
at com.icesoft.faces.renderkit.dom_html_basic.GridRenderer.encodeChildren(GridRenderer.java:208)
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:365)
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:492)
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:497)
at com.icesoft.faces.facelets.D2DFaceletViewHandler.renderResponse(D2DFaceletViewHandler.java:282)
Caused by: javax.faces.FacesException: javax.el.ELException: /pages/subviews/subviewTestCases.jspx @341,82 value="#{testCaseHandler.testCases}": Error reading 'testCases' on type de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_47
at javax.faces.component.UIData.getValue(UIData.java:611)
at com.icesoft.faces.component.panelseries.UISeries.getValue(UISeries.java:572)
Caused by: javax.el.ELException: /pages/subviews/subviewTestCases.jspx @341,82 value="#{testCaseHandler.testCases}": Error reading 'testCases' on type de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_47
at javax.faces.component.UIData.getValue(UIData.java:608)
Caused by: /pages/subviews/subviewTestCases.jspx @341,82 value="#{testCaseHandler.testCases}": Error reading 'testCases' on type de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_47
at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:83)
at org.springframework.orm.hibernate3.HibernateAccessor.convertJdbcAccessException(HibernateAccessor.java:424)
at org.springframework.orm.hibernate3.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:410)
at org.springframework.orm.hibernate3.HibernateTemplate.findByCriteria(HibernateTemplate.java:1055)
at org.springframework.orm.hibernate3.HibernateTemplate.findByCriteria(HibernateTemplate.java:1048)
at de.verit.klaros.dao.hibernate.HibernateDAO.findIds(HibernateDAO.java:463)
at de.verit.klaros.web.handler.TestCaseHandler.getSearchResults(TestCaseHandler.java:421)
at de.verit.klaros.web.handler.TestCaseHandler.getTestCases(TestCaseHandler.java:379)
at sun.reflect.GeneratedMethodAccessor821.invoke(null:-1)
at de.verit.klaros.web.handler.TestCaseHandler_$$_javassist_seam_47.getTestCases(TestCaseHandler_$$_javassist_seam_47.java:-1)
at sun.reflect.GeneratedMethodAccessor820.invoke(null:-1)
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:53)
Caused by: Hibernate operation: could not execute query; uncategorized SQLException for SQL [select this_.KL__ID as y0_ from KL_PO this_ where this_.CLASS='TC' and this_.SUCCESSOR is null and this_.ENABLED=? and this_.CONFIG=? order by this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc, this_.NAME asc]; SQL state [HY001]; error code [1038]; Out of sort memory; increase server sort buffer size; nested exception is java.sql.SQLException: Out of sort memory; increase server sort buffer size
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1055)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3491)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3423)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1936)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2060)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2542)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1734)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1885)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:205)
at org.hibernate.jdbc.AbstractBatcher.getResultSet(AbstractBatcher.java:208)
at org.hibernate.loader.Loader.getResultSet(Loader.java:1812)
at org.hibernate.loader.Loader.doQuery(Loader.java:697)
at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:259)
at org.hibernate.loader.Loader.doList(Loader.java:2232)
at org.hibernate.loader.Loader.listIgnoreQueryCache(Loader.java:2129)
at org.hibernate.loader.Loader.list(Loader.java:2124)
at org.hibernate.loader.criteria.CriteriaLoader.list(CriteriaLoader.java:118)
at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1597)
at org.jboss.seam.persistence.HibernateSessionProxy.list(HibernateSessionProxy.java:587)
at sun.reflect.GeneratedMethodAccessor72.invoke(null:-1)
at org.jboss.seam.ioc.spring.SeamManagedSessionFactoryBean$SeamManagedSessionHandler.invoke(SeamManagedSessionFactoryBean.java:300)
at $Proxy50.list(null:-1)
at org.hibernate.impl.CriteriaImpl.list(CriteriaImpl.java:306)
at org.springframework.orm.hibernate3.HibernateTemplate$36.doInHibernate(HibernateTemplate.java:1065)
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:419)
RE: Problem in renderResponse: javax.faces.FacesException: javax.el.ELExcep (Answer)
Hello Anders,
this problem has been tracked as issue KLAROS-654. Today we released Klaros-Testmanagement 2.4.2 which should fix this problem. Try the new version and let us know if you still have problems.
Tobias
