Unable to execute Test Cases
Prajaka Waje, modified 8 Years ago.
Youngling Posts: 14 Join Date: 10/7/15 Recent Posts
I have klaros 4.3.6 installed in my PC.
I have created test cases and set test environment as well. When I click on Test case execute button it is getting redirected to login page of klaros and one blank pop up window saying 'Job in Progress' appears on the same page.
Please find the attached screenshot.
Fabian Klaffke, modified 8 Years ago.
RE: Unable to execute Test Cases
Hi Prajakta,
may I ask if your installation is running behind a proxy server? If so, the URL of the application needs to be entered in 'Configure/System/Application URL'. That URL needs to match the URL you see in your browsers address bar.
Here is the corresponding section in our manual: http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Configure.Main-GeneralSettings.html#User-Manual.Configure.Main-GeneralSettings.Miscellaneous
P.S: We've recently released Klaros-Testmanagement 4.3.7, which contains several improvements and bugfixes (http://www.klaros-testmanagement.com/en/forum/-/message_boards/message/278437).
Yes, my application is running behind proxy server (Tomcat). I have already entered url 'http://192.168.56.1:18080/klaros-web/pages/login.seam' in 'Configure/System/Application URL'. And I am using the same url for klaros. But still I am getting this error.
RE: Unable to execute Test Cases (Answer)
Hi again,
Removing the adhered '/pages/login.seam' from the URL should do the trick (--> http://192.168.56.1:18080/klaros-web)
Thank you very much for this great help. Now I am able to excecute test cases and also I am able to export reports as well. emoticon
Hi Prajakta,
I'm glad I could help you emoticon! Have fun checking out the plethora of features Klaros-Testmanagement has to offer.
