Problem in renderResponse: null - Klaros Test Management - Forum - Klaros Test Management
Oskar Hlinka, modified 10 Years ago.
Youngling Posts: 4 Join Date: 10/16/09 Recent Posts
Hello
After upgrading form 2.0.4 to 2.2.2 using Posftgres db, i'm getting error: Problem in renderResponse: null when trying to manage test cases, in 2.0.4 it was working with no problem. Problem is just in 1 project (other projects are working fine). Is there any chance that in that project is used some unsupported symbol or something like this? Previous version worked fine..
The Stack Trace is:
The Stack Trace is:
Problem in renderResponse: null | |
at com.icesoft.faces.facelets.D2DFaceletViewHandler.renderResponse(D2DFaceletViewHandler.java:296) | |
at com.icesoft.faces.application.D2DViewHandler.renderView(D2DViewHandler.java:153) | |
at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:109) | |
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100) | |
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:139) | |
at de.verit.klaros.web.beans.application.LifecycleImpl.render(LifecycleImpl.java:50) | |
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:19) | |
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:122) | |
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:73) | |
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:28) | |
at com.icesoft.faces.webapp.http.common.standard.PathDispatcherServer.service(PathDispatcherServer.java:24) | |
at com.icesoft.faces.webapp.http.servlet.MainSessionBoundServlet.service(MainSessionBoundServlet.java:160) | |
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher$1.service(SessionDispatcher.java:42) | |
at com.icesoft.faces.webapp.http.servlet.ThreadBlockingAdaptingServlet.service(ThreadBlockingAdaptingServlet.java:19) | |
at com.icesoft.faces.webapp.http.servlet.EnvironmentAdaptingServlet.service(EnvironmentAdaptingServlet.java:63) | |
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:62) | |
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:22) | |
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:23) | |
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:153) | |
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) | |
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:56) | |
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) | |
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) | |
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) | |
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) | |
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128) | |
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) | |
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) | |
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286) | |
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845) | |
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583) | |
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447) | |
at java.lang.Thread.run(Thread.java:636) | |
Caused by: Problem in renderResponse: null | |
at de.verit.klaros.dto.mapper.TestCaseDTOMapper.getTestCaseDTO(TestCaseDTOMapper.java:62) | |
at de.verit.klaros.web.beans.wrapper.TestCaseWrapper.loadPersistentObject(TestCaseWrapper.java:603) | |
at de.verit.klaros.web.util.WrapperSet.get(WrapperSet.java:96) | |
at de.verit.klaros.web.util.WrapperSet.get(WrapperSet.java:24) | |
at javax.faces.model.ListDataModel.getRowData(ListDataModel.java:152) | |
at javax.faces.model.ListDataModel.setRowIndex(ListDataModel.java:186) | |
at com.icesoft.faces.component.panelseries.UISeries.processCurrentRowData(UISeries.java:145) | |
at com.icesoft.faces.component.panelseries.UISeries.setRowIndex(UISeries.java:136) | |
at com.icesoft.faces.component.ext.renderkit.TableRenderer.encodeChildren(TableRenderer.java:858) | |
at javax.faces.component.UIComponentBase.encodeChildren(UIComponentBase.java:832) | |
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:358) | |
at com.icesoft.faces.renderkit.dom_html_basic.GridRenderer.encodeChildren(GridRenderer.java:208) | |
at com.icesoft.faces.renderkit.dom_html_basic.GroupRenderer.encodeChildren(GroupRenderer.java:96) | |
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:365) | |
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:517) | |
at com.icesoft.faces.application.D2DViewHandler.renderResponse(D2DViewHandler.java:522) | |
at com.icesoft.faces.facelets.D2DFaceletViewHandler.renderResponse(D2DFaceletViewHandler.java:282) | |
RE: Problem in renderResponse: null
Hello Oskar,
first of all thank you for reporting this issue. To find out what exactly the problem is we need the complete stack trace from the log file. So please send the file "catalina.out" from the log folder of your Klaros installation to support@verit.de. Furthermore it could be very helpful to know the version of your PostgreSQL server, so we can better reproduce the error.
Tobias
Tobias
Hello Tobias
Thank you for quick reply, i just sent the log file with more information to your email.
Oskar
Oskar
Hello Oskar,
thank you for the e-mail with the log file and the information about your PostgreSQL server. We have located the problem and will provide a fix for this issue in our next release 2.3.0, which will hopefully be released today. Your Problem has been tracked as issue KLAROS-552.
Tobias
Tobias
RE: Problem in renderResponse: null (Answer)
Hello Oskar,
the 2.3.0 release is now available. Can you please check if this solves your problem?
Regards, Torsten
Regards, Torsten
Great, now it works fine, thank you for your quick and professional help.
There is one more problem that we noticed now and it is problem when rendering the Evaluation of Project.
Problem in renderResponse: javax.el.ELException: /pages/subviews/subviewProjectStatistics.jspx @100,75 value="#{testGraphicsBean.histogramChart}": Error reading 'histogramChart' on type de.verit.klaros.web.beans.charts.TestGraphicsBean_$$_javassist_seam_31
Not sure if it can be our configuration somewhere, let me know if you need catalina.out for this error.
stack trace is:
stack trace is:
Problem in renderResponse: javax.el.ELException: /pages/subviews/subviewProjectStatistics.jspx @100,75 value="#{testGraphicsBean.histogramChart}": Error reading 'histogramChart' on type de.verit.klaros.web.beans.charts.TestGraphicsBean_$$_javassist_seam_31 | |
at de.verit.klaros.web.beans.application.LifecycleImpl.render(LifecycleImpl.java:56) | |
at com.icesoft.faces.context.View$2$1.respond(View.java:48) | |
at com.icesoft.faces.webapp.http.servlet.ServletRequestResponse.respondWith(ServletRequestResponse.java:201) | |
at com.icesoft.faces.webapp.http.servlet.ThreadBlockingAdaptingServlet$ThreadBlockingRequestResponse.respondWith(ThreadBlockingAdaptingServlet.java:36) | |
at com.icesoft.faces.context.View$2.serve(View.java:76) | |
at com.icesoft.faces.context.View.servePage(View.java:139) | |
at com.icesoft.faces.webapp.http.core.SingleViewServer.service(SingleViewServer.java:52) | |
at com.icesoft.faces.webapp.http.common.ServerProxy.service(ServerProxy.java:11) | |
at com.icesoft.faces.webapp.http.servlet.MainSessionBoundServlet$4.service(MainSessionBoundServlet.java:114) | |
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83) | |
at org.jboss.seam.web.LoggingFilter.doFilter(LoggingFilter.java:60) | |
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69) | |
at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64) | |
at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45) | |
at org.jboss.seam.web.IdentityFilter.doFilter(IdentityFilter.java:40) | |
at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158) | |
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) | |
Caused by: Problem in renderResponse: javax.el.ELException: /pages/subviews/subviewProjectStatistics.jspx @100,75 value="#{testGraphicsBean.histogramChart}": Error reading 'histogramChart' on type de.verit.klaros.web.beans.charts.TestGraphicsBean_$$_javassist_seam_31 | |
at javax.faces.component.UIGraphic.getValue(UIGraphic.java:151) | |
at com.icesoft.faces.component.ext.renderkit.ImageRenderer.processSrcAttribute(ImageRenderer.java:48) | |
at com.icesoft.faces.renderkit.dom_html_basic.ImageRenderer.encodeBegin(ImageRenderer.java:66) | |
at javax.faces.component.UIComponentBase.encodeBegin(UIComponentBase.java:808) | |
at com.icesoft.faces.renderkit.dom_html_basic.DomBasicRenderer.encodeParentAndChildren(DomBasicRenderer.java:356) | |
Caused by: javax.el.ELException: /pages/subviews/subviewProjectStatistics.jspx @100,75 value="#{testGraphicsBean.histogramChart}": Error reading 'histogramChart' on type de.verit.klaros.web.beans.charts.TestGraphicsBean_$$_javassist_seam_31 | |
at com.sun.facelets.el.TagValueExpression.getValue(TagValueExpression.java:76) | |
at javax.faces.component.UIGraphic.getValue(UIGraphic.java:148) | |
Caused by: /pages/subviews/subviewProjectStatistics.jspx @100,75 value="#{testGraphicsBean.histogramChart}": Error reading 'histogramChart' on type de.verit.klaros.web.beans.charts.TestGraphicsBean_$$_javassist_seam_31 | |
at org.springframework.orm.hibernate3.HibernateTemplate.checkWriteOperationAllowed(HibernateTemplate.java:1186) | |
at org.springframework.orm.hibernate3.HibernateTemplate$12.doInHibernate(HibernateTemplate.java:696) | |
at org.springframework.orm.hibernate3.HibernateTemplate.doExecute(HibernateTemplate.java:419) | |
at org.springframework.orm.hibernate3.HibernateTemplate.executeWithNativeSession(HibernateTemplate.java:374) | |
at org.springframework.orm.hibernate3.HibernateTemplate.save(HibernateTemplate.java:694) | |
at de.verit.klaros.dao.hibernate.HibernateDAO.save(HibernateDAO.java:175) | |
at de.verit.klaros.web.handler.StatusMessageHandler.addStatusMessage(StatusMessageHandler.java:265) | |
at sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethodAccessorImpl.java:-2) | |
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) | |
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) | |
at java.lang.reflect.Method.invoke(Method.java:616) | |
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22) | |
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32) | |
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56) | |
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28) | |
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68) | |
at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:77) | |
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44) | |
at org.jboss.seam.core.SynchronizationInterceptor.aroundInvoke(SynchronizationInterceptor.java:32) | |
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107) | |
at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:185) | |
at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:103) | |
at de.verit.klaros.web.handler.StatusMessageHandler_$$_javassist_seam_7.addStatusMessage(StatusMessageHandler_$$_javassist_seam_7.java:-1) | |
at de.verit.klaros.web.beans.charts.TestGraphicsBean.getHistogramChart(TestGraphicsBean.java:436) | |
at de.verit.klaros.web.beans.charts.TestGraphicsBean_$$_javassist_seam_31.getHistogramChart(TestGraphicsBean_$$_javassist_seam_31.java:-1) | |
at javax.el.BeanELResolver.getValue(BeanELResolver.java:62) | |
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:53) | |
at com.sun.faces.el.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:72) | |
at org.jboss.el.parser.AstPropertySuffix.getValue(AstPropertySuffix.java:53) | |
at org.jboss.el.parser.AstValue.getValue(AstValue.java:67) | |
at org.jboss.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:186) | |
at com.sun.facelets.el.TagValueExpression.getValue(TagValueExpression.java:71) | |
Hello Oskar,
good to hear that your initial Problem is solved. Yes please send the catalina.out to support@verit.de. Sadly enough the displayed stacktrace sometimes omits hidden exceptions.
Regards, Torsten
Regards, Torsten
Oskar Hlinka:
Oskar,
we will have a (partial) fix for this [KLAROS-559] in the 2.3.1 release, scheduled for this evening. I still would like to know if this problem is reproducible and if it is still present after restarting tomcat.
Regards, Torsten
Regards, Torsten
Hello Torsten
I have finally got time to install the latest version, the renderer seems to work, but when i want to see charts, i can see just the first one and i get: There was an unknown error while rendering the chart.
as Status message.
as Status message.
Christian Petry, modified 10 Years ago.
Youngling Posts: 3 Join Date: 2/12/09 Recent Posts
Hello Oskar,
we still need to find the underlying cause of your problem, so if you find the time please send the catalina.out log to kontakt@verit.de. I suspect there is something wrong in the chart data generation but I need the stacktrace to investigate.
Christian
Christian
