Klaros-Testmanagement version 1.11.0 released
The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.11.0!
New features:
o Implement the new Klaros-Core export function into the web frontend.
o Provide a System Under Test Overview Report.
o Create an Environment Overview Report.
o An exporter that is able to export the master data and dynamic data.
o Create a hudson plugin which is able to feed test results into Klaros.
o Error while generating a project overview report when logged in via JIRA.
o The commandLink of the last test case result on the statistics page is not clickable.
o After a recovery the test plan results has no test case results anymore.
o After a recovery the test plans are not executable anymore, because they have no test cases.
o The open test plans page shows a useless tab entry.
Changes:
o Separate the 'create.sql' into two scripts. One to drop and the other to create the database.
More details may be found at http://www.verit.de/.
67657 Kaiserslautern
Europaallee 10
Germany
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
