ENV/SUT can't be deleted - Klaros Test Management - Forum - Klaros Test Management
Torsten G, modified 9 Years ago.
Youngling Posts: 4 Join Date: 1/7/15 Recent Posts
we have some TC-results deleted over Evaluate - Test Runs - Delete this Test run.
If we also try to remove the ENV (or also SUT) we've got the result:
But, in ENV (or SUT) all the tabs ("Test Case Results", "Test Suite Results", "Test Runs") are empty!
Environment: Klaros 4.2.6 EP with default database Apache Derby
Torsten G.
"Für dieses Objekt liegen bereits Testergebnisse vor, deshalb kann die Testumgebung (Testsystem) nicht gelöscht werden." |
Torsten G.
RE: ENV/SUT can't be deleted
this is indeed a bug, the deleted flag of the test runs (which are still present in the database after deletion) is not honored in this case.
Tracked as bug KLAROS-2543 towards release 4.2.8.
Thanks for pointing that out!
Regads,
Regads,
