Change revision of a Test Case from Excel file
Sorry, is it possible to change or increase the number of Revision of a Test Case importing from an Excel file?
Teorically it is possible to fill <Revision> field with different numbers, but when the TC is imported, it always is filled with <revision=1.0>
Angel Hidalgo
Patrick Reilly, modified 10 Years ago.
RE: Change revision of a Test Case from Excel file (Answer)
Hi Angel,
I can see how this could be confusing!
The revision field is included so that this same format can be used for test case export. The revision ID is a field which is used by Klaros-Testmanagement to track the order of revisions of test cases, and new test cases are always assigned the revision ID "1.0".
From our point of view it doesn't make much sense to have a test case labeled "1.1" when a "1.0" does not exist in Klaros.
I will add a note to the documentation explaining this.
