Which redmine version is suitable for klaros 3.8 - Klaros Test Management - Forum - Klaros Test Management
Joby V A, modified 10 Years ago.
Hi ,
I would like to install klaros 3.8 on one of my server. May I know which redmine version is compatible with klaros 3.8.
Joby
Joby
RE: Which redmine version is suitable for klaros 3.8
Hi Joby,
All versions up to and including Redmine 2.3.4 should work. We are testing against Redmine 2.3.3 in our integration tests.
This applies to the current 4.1.1 release of Klaros-Testmanagement as well.
P.S.: Moved this thread to the Q&A category.
Youngling Posts: 14 Join Date: 1/14/14 Recent PostsTorsten Stolpmann:
Hi Joby,
Thank you for your reply.
I would like to know one more thing along with this. Is it possible to access klaros from a remote machine without specifying a particular port. That means I would like to access my klaros installation as 'klaros.mydomain.com' . Please let me know.
Joby.
Hello Joby,
you would normally do this using mod_proxy on an Apache webserver.
Search for "Apache Tomcat ProxyPass ProxyPassReverse", there is tons of helpful information out there like e.g. like e.g. http://wiki.apache.org/httpd/TomcatReverseProxy.
Hello Joby,
I am trying this installation on a shared hosting environment. One more thing, how can I install klaros jar file in a server. When I execute the java command it shows cannot open display.
Joby
Jedi Council Member Posts: 755 Join Date: 2/12/09 Recent PostsI am trying this installation on a shared hosting environment.
Meaning what?
Add -Djava.awt.headless=true to your command line.
