cannot edit steps and no dashboard in v3.7.7 on linux with MySQL - Klaros Test Management - Forum - Klaros Test Management
Juan Camacaro, modified 11 Years ago.
Youngling Post: 1 Join Date: 3/21/13 Recent Posts
we are evaluating klaros community and installed v3.7.7 on linux, opened the application and worked (Dashboard page is there after creating the first project) , changed hibernate.properties to mySQL database, and the dashboard does not work, nor I can edit TestCases Steps, since the tab is disabled.
Here are some parts from the Stack Trace
Problem in renderResponse: /pages/subviews/evaluate/reporting/dashboard/dashboard.jspx @127,69 id="dashboardReport#{reportsDashboard.reports.indexOf(report)}" Could not instantiate Seam component: reportsDashboard
Caused by: could not execute query; SQL [select avg(cast(this_.DURATION as double)) as y0_ from K_TEST_CASE_RESULT this_ where this_.CONFIG=? and this_.ENABLED=?]; nested exception is org.hibernate.exception.SQLGrammarException: could not execute query
at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:92)
I can put the complete stack trace if it helps.
Thanks in advance for any ideas.
RE: cannot edit steps and no dashboard in v3.7.7 on linux with MySQL
Hi Juan,
Can you please send us the complete log file to support@verit.de and state the version of your MySQL installation?
RE: cannot edit steps and no dashboard in v3.7.7 on linux with MySQL (Answer)
As we already verified via email you will need org.hibernate.dialect.MySQL5InnoDBDialect in your hibernate.settings file instead oforg.hibernate.dialect.MySQLDialect for your database version, as shown below:
Sorry for the misleading documentation, this has been corrected in the FAQ and forum as well as the upcoming documentation now.
hibernate.dialect=org.hibernate.dialect.MySQL5InnoDBDialect | |
hibernate.connection.url=jdbc:mysql://localhost:3306/klaros | |
