Backup and restore project - Klaros Test Management - Forum - Klaros Test Management
shashank rb, modified 11 Years ago.
Youngling Post: 1 Join Date: 1/17/13 Recent Posts
I have installed Klaros 3.6.9 on my system and i have done all the steps like writing test cases and so on then i took the backup of the project.
Is it possible to restore the same project in another system which is installed newly?
RE: Backup and restore project
Hello shashank,
There are two approaches you may take for changing your installation system:
Method: 1: File Transfer
Method: 2: Using XML Backup/Restore
Personally I would recommend using method 1 here as it is faster and more reliable. In any case please consider updating to version 3.7.3, which contains a lot of bug fixes and improvements and is typically much faster than version 3.6.9.
- Install Klaros-Testmanagement 3.6.9 (Windows Download / Linux Download) on your target system
- Transfer the content of your <user_home>/.klaros folder to the home directory of the user on your target system.
- In case you have changed the database settings you might also need to transfer the database to another system
- Before attempting this path you should strongly consider upgrading to version 3.7.3 as we have extended the backup format in 3.7 to include more information in the backup. It is good practice to have a backup of your .klaros folder at hand before upgrading.
- Export your project to XML on your source system and import it on your freshly installed target system. It is mandatory to use the same version of Klaros-Testmanagement for the export and import procedure.
- The XML backup does not include binary attachments of your test cases or test results, if you need those as well you have to manually transfer the .klaros/repository folder
