Setting up a domain to use for Klaros - Klaros Test Management - Forum - Klaros Test Management
Musa Haidari, modified 4 Years ago.
Good day.
After the restart, when I type in the URL http://qa.example.com:18080/ in the browser, I get:
This qa.example.com page can’t be foundNo webpage was found for the web address: http://qa.example.com:18080/HTTP ERROR 404========================ANY HELP IS MUCH APPRECIATED.
Thank you.
<Host name="qa.example.com" debug="0" appBase="webapps/klaros-web" | |
unpackWARs="false" | |
xmlValidation="false" xmlNamespaceAware="false"> | |
<Logger className="org.apache.catalina.logger.FileLogger" | |
directory="logs" prefix="qa.example.com\_log." suffix=".txt" timestamp="true"/> | |
</Host> |
<?xml version='1.0' encoding='utf-8'?> | |
<Context displayName="qa.example.com" docBase="" path="" | |
workDir="work/Catalina/qa.example.com/_"> | |
</Context> |
Thank you.
RE: Setting up a domain to use for Klaros
Hi Musa,
RE: Setting up a domain to use for Klaros (Answer)
Hello Musa,
Dear team,
Hello Musa,
