Klaros-Testmanagement version 3.5.6 released
We are happy to announce the release of Klaros-Testmanagement version 3.5.6.
This release introduces a significant performance increase and reduced memory requirements as well as a general keyword search, change history and sophisticated conflict handling for concurrent write accesses to database objects. Bugzilla 4.2 support has also been added.
Watch this space for a detailed future update on these and other new and noteworthy changes.
Existing users are strongly encouraged to upgrade.
Enjoy working with Klaros-Testmanagement!
Release-Notes:
Version 3.5.6 - 2012-04-30:
[KLAROS-1591] - Broken partial submit synchronization on the edit test case page may lead to invalid value assignment
Version 3.5.5 - 2012-04-27:
[KLAROS-1590] - Attachments added during test runs do not appear in the application
[KLAROS-1587] - Attachment repository user authentication error - unable to upload attachment
[KLAROS-1586] - Leading whitespace in the issue ID can lead to an error on the link issues page
[KLAROS-1585] - History relation string not available for adding/removing attachments
[KLAROS-1584] - Unable to delete bug tracker instances
[KLAROS-1582] - Missing status message for issue creation
[KLAROS-1515] - Only the builtin admin account can authenticate against the content repository
[KLAROS-1588] - Allow restoration of Issue Management Systems and deletion of IMSs with assigned issues
Version 3.5.4 - 2012-04-19:
[KLAROS-1580] - Continuing execution of test suites which contain unexecutable test cases sometimes leads to an error
[KLAROS-1577] - <bridgehead> tags appearing in documentation
[KLAROS-1576] - Test suite execute no longer uses the assigned system under test
[KLAROS-1575] - Wrong command line in the PDF documentation for the Linux init script
[KLAROS-1570] - Cloning test cases containing attachments may lead to an error
[KLAROS-1567] - Bulk adding test cases to a test suite throws an exception in the presence of unsaved test cases
[KLAROS-1566] - API Class diagrams are missing from the HTML documentation
[KLAROS-1568] - Add support for bugzilla 4.2
Version 3.5.3 - 2012-03-30:
[KLAROS-1565] - Custom field display order is not properly maintained in some cases
[KLAROS-1564] - Temporary skipped test cases are denoted as finished in their corresponding job
[KLAROS-1563] - Concurrent changes to a test case leads to an error in some cases
[KLAROS-1561] - Viewing test cases after purging a project may lead to an error
[KLAROS-1558] - Executing a job with the test suite, system under test and test environment set may lead to an error
[KLAROS-1557] - Editing unsaved cloned test cases without prior saving throws an error
[KLAROS-1556] - Categories link visible in the community edition
[KLAROS-1554] - Revision/Cloned test cases must clone their attachment relations to allow proper deletion of the project
[KLAROS-1560] - Importing test cases from other projects should also transfer their custom attributes
[KLAROS-1559] - The installer should allow to overwrite never distribution content when downgrading
Version 3.5.2 - 2012-03-16:
[KLAROS-1554] - Revisioned/Cloned test cases must clone their attachment relelations to allow proper deletion of the project
[KLAROS-1553] - Database migration may lead to a lockup
[KLAROS-1549] - Editing unsaved objects does not properly redirect to the details page
[KLAROS-1550] - Update the Redmine connector libraries to work with Redmine 1.3
[KLAROS-1545] - Do not let the login page expire
Version 3.5.1 - 2012-03-07:
[KLAROS-1548] - Migration for PostgreSQL is unable to update the pending field correctly
[KLAROS-1547] - Klaros creates unknown test results for aborted single test case executions
[KLAROS-1540] - Setting the email sender address has no effect
[KLAROS-1546] - The dialog options for finishing a test case execution should give a better explanation of their intent
Version 3.5.0 - 2012-02-29:
New Features:
[KLAROS-1472] - Implement a global common search covering all relevant database items
[KLAROS-1452] - Allow to bulk assign test cases to a selected group of test suites
[KLAROS-1438] - Implement a common Excel import format for test case data
[KLAROS-1431] - Add a change history to every Klaros object
[KLAROS-1251] - Allow the ad-hoc creation of a test suite from existing test results
[KLAROS-1244] - Allow to manually issue a test case retest from the test result page
[KLAROS-563] - Add server monitoring for large installations
[KLAROS-1544] - System under test on test suite revision history tab is only displayed as a number
[KLAROS-1543] - Test suite overview report lists previous revisions of a test suite
[KLAROS-1539] - Do not use a domain for default sender address in generated E-Mails
[KLAROS-1506] - No user feedback when trying to upload attachments with an empty file name input field
[KLAROS-1505] - The properties page is displayed after save is pressed on the attachment page of a test case.
[KLAROS-1504] - Rollover text for adding a Teststep is missing
[KLAROS-1503] - Double clicking the test case properties tab resets the select menus to their initial state
[KLAROS-1499] - Skipping single test steps in test suite executions does not work properly under certain conditions
[KLAROS-1489] - Renderexception on first login
[KLAROS-1479] - Klaros crashes when clicking on + icon in category view when there are no categories defined yet
[KLAROS-1478] - Wrong errormessage when clicking on "assign to category" without having defined any categories
[KLAROS-1474] - Job comments and time blocks do not carry a reference to their containing project
[KLAROS-1471] - Using the browser back button to navigate to the login page yields an error
[KLAROS-1469] - Klaros config page shows license expired when less than 24 hours are left
[KLAROS-1468] - Unable to update an expired enterprise license from the gui
[KLAROS-1457] - Installation requires JAVA_HOME/bin to be part of the system path
[KLAROS-1449] - Exception while editing a test step description
[KLAROS-1448] - Import project list counts deleted test cases towards the total number of test cases
[KLAROS-1401] - NPE when expanding a testsuite job node
[KLAROS-1394] - The sample template for new report templates is always in PDF format regardless of the format choosen
[KLAROS-1373] - Language icons are not visible when in a SSL proxied environment
[KLAROS-1294] - Dirty flag is apparently set for no reason on define details pages
[KLAROS-1542] - Provide a better method to reorder tests while maintaining a test suite
[KLAROS-1529] - When creating jobs in a sub-job view they should automatically be assigned to that parent
[KLAROS-1507] - Directly take user to the user defined properties page instead of the project details page
[KLAROS-1501] - Move the categories and filter/sort panel activators to the data table header line
[KLAROS-1500] - Add paging controls to the test step editor page
[KLAROS-1498] - Add image dimensions to speed up page rendering
[KLAROS-1496] - Creating or adding a subcategory should always expand the parent category
[KLAROS-1495] - Global select flag should be unset when an unsaved new object is present in data tables
[KLAROS-1482] - Improve database performance
[KLAROS-1473] - Include controls for New, Save, Back, etc. at the top of define pages as well
[KLAROS-1439] - Allow searching/sorting in sub-job tables
[KLAROS-1436] - Make the color distinction between success and skipped tests more prominent
[KLAROS-1432] - Extend the quick search functionality to support more object types and abbreviated ids
[KLAROS-1426] - Implement the difference between temporary and permanently skipped test results
[KLAROS-1424] - Guide the user to the user defined properties settings page for the project when showing the user defined properties detail pages
[KLAROS-1407] - Enable Query caching
[KLAROS-1400] - Collapse the tree of category entries when selecting a category
[KLAROS-1384] - Misleading error message for checking empty application URLs
[KLAROS-1249] - The creation of issues should be possible at every step of a test execution
[KLAROS-1005] - Duplicate test case references in a test suite should be marked as such
[KLAROS-832] - Replace the checkbox "The script has parameters" for report parameter creation
