login to the Klaros running on different network using ip address
Mohamed Ashraf J, geändert vor 4 Jahren.
Youngling Beitrag: 1 Beitrittsdatum: 04.02.20 Neueste Beiträge
login to the Klaros running on different network using ip address(http://localhost:18080/klaros-web/) replaced local host with ipaddress of the system running on different network, getting below error. Can you please help us here.
RE: login to the Klaros running on different network using ip address (Antwort)
Hi Mohamed,
is your Klaros Testmanagement installation running behind a proxy server? If this is the case, then the application URL
needs to be entered in 'Configure/System/Application URL'.
That URL needs to match the URL you see in your browser's address bar.
Here you can find the corresponding section in our manual:
http://www.klaros-testmanagement.com/files/doc/html/User-Manual.Configure.Main-GeneralSettings.html#User-Manual.Configure.Main-GeneralSettings.Miscellaneous
