Setting up a domain to use for Klaros
Musa Haidari, geändert vor 4 Jahren.
Good day.
<Host name="qa.example.com" debug="0" appBase="webapps/klaros-web"
        unpackWARs="false"
    xmlValidation="false" xmlNamespaceAware="false">
<Logger className="org.apache.catalina.logger.FileLogger"
directory="logs"  prefix="qa.example.com\_log." suffix=".txt" timestamp="true"/>
</Host>
<?xml version='1.0' encoding='utf-8'?>
<Context displayName="qa.example.com" docBase="" path=""
workDir="work/Catalina/qa.example.com/_">
</Context>
After the restart, when I type in the URL http://qa.example.com:18080/ in the browser, I get:
This qa.example.com page can’t be foundNo webpage was found for the web address: http://qa.example.com:18080/HTTP ERROR 404========================ANY HELP IS MUCH APPRECIATED.
Thank you.
RE: Setting up a domain to use for Klaros
Hi Musa,
RE: Setting up a domain to use for Klaros (Antwort)
Hello Musa,
Dear team,
Hello Musa,
