Klaros-Testmanagement version 3.7.9 released - Klaros Test Management - Forum - Klaros-Testmanagement
Patrick Reilly, geändert vor 6 Jahren.
We are pleased to announce the release of Klaros-Testmanagement version 3.7.9.
This release includes a major speedup for servers with large data sets, in particular for large numbers
of projects, or projects with large numbers of test cases or jobs. Java 7 is also officially supported as
of this release.
Version 3.7.9 contains several bug fixes and improvements. Users are strongly recommended to update to this version.
Release Notes:
Version 3.7.9 - 2013-05-17:
[KLAROS-1881] - Dashboard reports are not updated for 10 minutes after the first result is created in a project
[KLAROS-1876] - Exception during project import
[KLAROS-1875] - Do not create duplicate ORDER BY statements
[KLAROS-1874] - Attempting to save a property definition for test runs with no name causes an exception
[KLAROS-1882] - Clarify the text in the latest success rate report
[KLAROS-1878] - Allow to add attachments to test results on the test suite runner summary page and the test result page
Version 3.7.8 - 2013-04-22:
[KLAROS-1873] - The test progress history report does not properly ignore skipped test cases
[KLAROS-1867] - Errors during table export for the jobs by user table
[KLAROS-1864] - Setting a step result to failed may not result in a test case result being failed in case of trailing passed step results
[KLAROS-1872] - Don't allow creation of new objects while unsaved changes exist
[KLAROS-1871] - Custom reports should not need an active project to be executed
[KLAROS-1868] - Improve list rendering speed, especially for remote issues
[KLAROS-1866] - Support skipped test case results in QFTest and TestNG style JUnit result files
Version 3.7.7 - 2013-03-14:
New Features:
[KLAROS-1838] - Allow specification of dynamic test run parameters
[KLAROS-1849] - Conflict resolution on test case step edits does not work properly
[KLAROS-1848] - JDBC-based Migration does not work under Linux/MySQL default installations
[KLAROS-1841] - Duplicating a test case should put the new test case into the same category
[KLAROS-1836] - Unable to save different properties instances of the same dashboard report type
[KLAROS-1835] - The bulk add test cases button on the maintain test suites page causes an error
[KLAROS-1831] - Issue management custom property fields are not rendered after first forced authentication
[KLAROS-1830] - Password field gets cleared upon focus switch in the user password dialog
[KLAROS-1829] - Project edit icon renders with border under IE
[KLAROS-1857] - Block UI interactions for long running submits
[KLAROS-1856] - Allow filtering of test cases by state
[KLAROS-1854] - The print page for test suite results should show the details of the executed test suite
[KLAROS-1852] - Allow to search for summary and description test result fields
[KLAROS-1846] - Improve report configuration dialog for dashboard to avoid confusion with active project flag
[KLAROS-1845] - Jobs for test suite runs should reflect the success rate of the contained test suite results
[KLAROS-1843] - Replaced execute test case and execute test suite pages with popup
[KLAROS-1842] - Show test suite user-defined properties when beginning test suite execution
[KLAROS-1840] - Improve confusing status message when trying to assign objects to category while in edit view
[KLAROS-1839] - Speed up the rendering of the change history page
[KLAROS-1837] - Show the SUT/Test Environment select lists in their natural order
[KLAROS-1834] - Allow page size selection and excel export on the search result page
[KLAROS-1833] - The attachment table for test cases should cover the whole page width
[KLAROS-1748] - Show a reason for greyed out upload/import buttons on result import page
Version 3.7.6 - 2013-02-08:
[KLAROS-1828] - Possible problem in database migration
[KLAROS-1827] - Add the test suite name field to the full text search indices
[KLAROS-1387] - Provide a way to easily access the project settings of the currently selected project
Version 3.7.5 - 2013-02-05:
New Features:
[KLAROS-1815] - Allow direct linking to test objects from outside the application
[KLAROS-1825] - Only the highest revision of test cases may be added to test suites
[KLAROS-1823] - Deleted attachments reappear in new revisions of a test case
[KLAROS-1822] - Status message refresh threads are not properly garbage collected
[KLAROS-1821] - The selected system under test and test environment on the test result import page are not always updated when a project is refreshed
[KLAROS-1818] - Problem while sending test emails
[KLAROS-1817] - Dropdown menus for user-defined enumeration properties are empty in the filter/sort menu
[KLAROS-1814] - Unable to cancel dashboard configuration dialog
[KLAROS-1824] - Allow the use of URIs in the traceability field of test cases
[KLAROS-1405] - Allow to specify more parameters when showing the user job occupation graph
[KLAROS-1344] - Add the possibility to link new created issues to a test case on the "Create issue" view
[KLAROS-1100] - Revision comments should be editable after their creation
[KLAROS-1091] - Display a warning dialog when copying test cases to a new project
[KLAROS-637] - Add an optional default value to a user defined property definition
Version 3.7.4 - 2013-01-18:
[KLAROS-1813] - Error when trying to display an external issue which has been removed from the external issue management system
[KLAROS-1811] - Deleted attachments may not be re-added to the same test case
[KLAROS-1809] - The dynamic properties of the current executed test case during the test suite execution are taken from stale data from the last test case excution
[KLAROS-1808] - The full text search aborts with an error upon orphaned test case steps
[KLAROS-1807] - Default enum property field not properly transferred when copying test cases between projects
[KLAROS-1806] - Imported projects are not listed in the export project list immediately
[KLAROS-1805] - Problem displaying change references to existing users in the change history of objects from imported projects
[KLAROS-1803] - Foreign key constraint violation when finally deleting projects
[KLAROS-1800] - Unable to switch to a different set of env/sut lists in already configured reports
[KLAROS-1798] - Problem moving first test case step in the tabbed test case step view
[KLAROS-1796] - Deleting a category group after making changes but not saving can lead to an error
[KLAROS-1812] - Lower memory footprint by evicting expired cache objects on a regular schedule
[KLAROS-1810] - Offer to end the test case execution in the tabular view as soon as all test steps have been assigned results
[KLAROS-1804] - The user status messages should be excluded from the xml backup
[KLAROS-1802] - Improve the speed of test case transfers between projects
[KLAROS-1801] - Support a 'Not Like' filter statement when filtering table content
[KLAROS-1362] - When entering the issue related pages users should be shown a link to the project setup when no IM system has yet been associated
Version 3.7.3 - 2012-12-13:
[KLAROS-1795] - Some multi-select boxes on the Create Issue page are not properly scrollable
[KLAROS-1794] - Testing the connection to an unreachable proxy can cause Klaros to be unreachable in some network setups
[KLAROS-1793] - Evaluate-Create Issue always places a link to a test case after an issue has been created in the test runner
[KLAROS-1791] - Clicking retest on the test suite results page can lead to an error
[KLAROS-1787] - Missing resource deleteLockedParam when trying to delete a locked issue management system
[KLAROS-1786] - Test result attachment upload button does not render correctly on IE8
[KLAROS-1785] - Redmine custom list fields must allow empty selections when set to not required
[KLAROS-1778] - Clicking on the user-defined properties tab leads to an exception in the Community Version
[KLAROS-1784] - The need and the way to assign issue trackers to projects must be better reflected in the application and documentation
[KLAROS-1783] - The documentation should be clearer about the application URL setting
Version 3.7.2 - 2012-11-23:
[KLAROS-1781] - Editing categories directly after creation can lead to an error
[KLAROS-1780] - Test cases remain deletable for a limited time after execution
[KLAROS-1779] - Dynamic properties are showing up in the order criteria selection
[KLAROS-1777] - Skipping test cases in a job execution can lead to an error
[KLAROS-1776] - Editing a test case step result can lead to an error
[KLAROS-1774] - Creating an issue during execution of a test suite leads to an error
Version 3.7.1 - 2012-11-14:
[KLAROS-1772] - Manually importing test results without a referencing job fails
[KLAROS-1771] - Users are able to disable their own account
[KLAROS-1770] - Cross-link resolution of object ids in the execute and evaluate sections may fail when the selected item has been excluded from the list view
[KLAROS-1769] - The database migration of the subjob progress calculation may fail for certain nested sub job configurations
[KLAROS-1767] - Do not allow assigning of objects to the category which contains them
[KLAROS-1766] - Transferring test cases causes an error if the test cases contain user-defined properties
[KLAROS-1765] - User Defined enumeration values cannot be renamed
[KLAROS-1762] - Transfer test cases tab is enabled if only the selected project has test cases
[KLAROS-1757] - Backups of very large amounts of projects can lead to HTTP error 414 (Request-URI Too Large)
[KLAROS-1773] - The changes page for Test Case Results should show localized strings for Passed/Failed/etc.
[KLAROS-1764] - Show the initial credentials on the login screen until the first project has been created
[KLAROS-1763] - The full text search indexer should only be launched after initialization of the database
[KLAROS-1761] - Add a warning that the initial account/password combinations are still active
[KLAROS-1760] - Show the version number on the greeting screen of the installer
Version 3.7.0 - 2012-11-07:
New Features:
[KLAROS-1711] - Track and display the job execution success rate
[KLAROS-1675] - Add support for XML import of test cases
[KLAROS-1671] - Implement an improved XML based backup format including all database objects with their complete history
[KLAROS-1668] - Allow access to the related results from the details pages
[KLAROS-1629] - Add support for importing TestComplete result files
[KLAROS-1751] - Rapidly clicking cancel on the issue management authentication dialog leads to an error
[KLAROS-1750] - Unable to create issues in Trac when no versions are specified for the project
[KLAROS-1747] - Bulk add test cases to test suites test case list is filtered and sorted like the test cases page
[KLAROS-1689] - Dynamic property selections may get reset when double clicking on other tabs on the same page
[KLAROS-1321] - Sorting test suites by SUT omits entries with no SUT defined
[KLAROS-1242] - Searching for user-defined properties does not include uninitialized values
[KLAROS-999] - Closing the status message bar on the test runner closes the bar on the main page as well
[KLAROS-1745] - Importing results for an automated test case should set the related job to complete and track the success rate
[KLAROS-1731] - Prevent admins and testmanagers from downgrading their accounts to testmanagers or testers role
[KLAROS-1713] - Try to raise an existing test execution window if it is hidden when starting tests
[KLAROS-1712] - The status area on the test case execution window should only be visible when messages are generated there
[KLAROS-1597] - Test runner does not adequately display the current step in single step view
[KLAROS-1596] - Edit step functionality in the test runner reworked to write comments to individual steps
[KLAROS-1519] - Allow the navigation to user pages
[KLAROS-1337] - Allow filtering of objects by creation date and last updated
[KLAROS-1163] - Show the creator, last editor, creation date, last change date for all database objects
[KLAROS-1123] - The job table should mark jobs that are way behind schedule by color marks
[KLAROS-778] - Input fields should display their content as a tool tip
[KLAROS-565] - Extend the test suite and test case result search options
of this release.
- The XML Backup and Recovery function now includes more elements, like users who have contributed to the exported projects.
- Test Cases may now be imported through an XML Import interface(see the manual for details).
- The Print View function has been extended to more Klaros-Testmanagement artifacts.
- Test Results may now be imported from the TestComplete result file format.
- Jobs now show their overall Success Rate - the percentage of linked test runs which were completed with the result "Passed".
- Test Results may be edited after test execution is complete. Test Results whose result field is changed will be marked as altered.
- Custom Fields in Bugzilla, Mantis, Redmine and Trac are now supported.
- Test Runs and Test Results are visible from the details page of their related objects.
Release Notes:
New Features:
New Features:
New Features:
