The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.9.0!
New features: o Get the current version from the pom.xml and write it into a properties file in the 'src' folder of Klaros-Web.
Fixed Bugs: o A JSF Exception is thrown if a generated report is empty. o Remove the data table of all projects in the test run history view. o The test run history should allow to choose a start and end date for the report. o After password change the email-validator complains, if no email was given. o The descriptions in the test plan report overflow the margin on the right hand side area. o HTML Documentation is missing images in section 1.1.
Changes: o The documentation should mention that the Vista install path should not be the Programs folder or that UAC must be disabled in this case. o Update User Manual with the new Test Plan Report. o Add an entry for the '.klaros' folder in the home directory that holds all property files. o The installer should provide the latest release notes as a readme file.
verit Informationssysteme GmbH is an independent software vendor focusing on tools for software quality management and software test automation, located in Kaiserslautern, Germany.
verit Informationssysteme GmbH 67657 Kaiserslautern Europaallee 10 Germany Phone: +49 631 520 840 00 Fax: +49 631 520 840 01
