Announcements
Klaros-Testmanagement version 1.7.0 released
The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.7.0!
New features:
o Show the Build number in the version information
o The possibility to reorder the list of test cases in a test plan and the steps of a test case
o Creating a user with empty name and password
o Duplicated 'Environment' label on the import page
o The Install prerequisites section mentions wrong prerequisites
Changes:
o Validate e-mail format.
o The 'admin' needs the possibility to edit the JIRA URL in the administration section
o The Importer should only commit once, instead commiting every single object
o Add status messages to the search functions
o Reduce the size of the steps dialog in the test case execution
o The new permission schemes must be implemented into the user search
o Search criteria 'role' should use a combo box
o Searching users without entering search criterias should list all defined users
o It should not be possible for a user to delete its own user
o The ImportServlet should accept the names of the SUT and Environment instead of the IDs
o The ImportServlet should return a message or signal to the plugin
o A validator for the URL in Administration|General|Appliation URL is needed
o The test step editor should allow the editing of a single test step
67657 Kaiserslautern
Europaallee 10
Germany
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
0 (0 Votes)
