Klaros-Testmanagement version 3.2.3 released
So what does the new version provide?
For users of the Enterprise Edition: A complete new Planning component, which allows to assign test execution and other jobs to users.
Jobs can be nested as well as individualy assigned and accounted for.
User occupation can be tracked and viewed.
Community and Enterprise Edition:
  • The test step definition interface has been redesigned to allow more input and improved usability
  • Redmine 1.0 and later is now finally supported
  • Full Support for Jira 4.1 - you no longer need to disable the form token
  • Issues can now be created directly without having to run tests
  • Test cases can be copied from one project to another
And as always an impressive list of smaller improvements, tweaks and bug fixes.
We hope you will enjoy the new release and look forward to your suggestions and feedback.
Release Notes:
Version 3.2.3 - 2010-12-22:
Version 3.2.2 - 2010-11-23:
Version 3.2.1 - 2010-11-09:
Version 3.2.0 - 2010-11-03:
New Features:
0 (0 Votes)
