Klaros-Testmanagement version 2.5.3 released
Release Notes for Klaros-Testmanagement version 2.5.3:
development projects.
manually executed test cases.
Version 2.5.3 - 2010-03-10:
[KLAROS-720] - Invalid test run percentage calculations for empty test runs
[KLAROS-718] - Problem opening the test case overview page in a reimported project
[KLAROS-717] - Textfield labels shoud be top-aligned on read only entries to allow better reading
[KLAROS-709] - Editing an unsaved test plan duplicates it
[KLAROS-706] - Misleading hint on testcase details page
[KLAROS-705] - Problem when deleting attachments of a test case
[KLAROS-704] - Deactivating an unsaved project causes a duplication of the project
[KLAROS-699] - Application freezes when pdf reports are created too often
[KLAROS-697] - RuntimeException when finishing a test run
[KLAROS-694] - When canceling an issue creation with wrong parameters the test execution is canceled as well
[KLAROS-715] - Validate the URL and project of an issue management system after save or update
Version 2.5.2 - 2010-03-05:
[KLAROS-690] - JUnit Error descriptions are not imported properly
[KLAROS-686] - Optimistic locking conflict during project selection
[KLAROS-685] - Test execution client window too small in IE
[KLAROS-684] - Filter Selector not properly rendered in IE
[KLAROS-683] - Wrong handling of missing state definitions for test cases
[KLAROS-682] - Exception deleting an atachment of a revisioned test case
[KLAROS-680] - When editing the email adress of a user the new destination address is not picked up by the email service test mail
[KLAROS-679] - Unresolved/broken entries in the release history
[KLAROS-678] - A user with the role "tester" is able to edit the steps of a test case
[KLAROS-677] - Broken status message after the import of a project
[KLAROS-676] - NullpointerException when browsing the results of an imported test plan
[KLAROS-651] - The manual suggests that klaros will create the database on a full grown database system.
[KLAROS-646] - Changing a value of a in the test case details page drop down does not enable the save button
[KLAROS-571] - Missing translation for test priority fields
[KLAROS-393] - The revision of a test case is always incremented when the test case details page has been left via the save button.
[KLAROS-667] - The documentation should mention the browser requirements in more detail
[KLAROS-562] - Use lesser memory when importing or exporting large projects
[KLAROS-330] - The new button on the testcase details page does not save the changes or ask whether to do so
Version 2.5.1 - 2010-02-14:
[KLAROS-674] - Error Displaying a test case from the results page as a tester
[KLAROS-673] - Wrong injection class breaks test result import servlet
[KLAROS-675] - Test case revision list needs a better formatting
Version 2.5.0 - 2010-02-12:
New Features:
[KLAROS-663] - A test case should be able to contain attachments
[KLAROS-631] - Support the import of QFTest result files
[KLAROS-580] - Support Redmine as an issue tracking system
[KLAROS-523] - Show the history of a test case
[KLAROS-522] - A test case result should be able to contain attachments
[KLAROS-670] - Locales reporting empty languages causes illegal Report URLs
[KLAROS-668] - Missing default resource bundle entry: urlNotAccessible
[KLAROS-666] - Numberformat exception in the test progress history report
[KLAROS-665] - Numberformat Exception in the test progress report when the configuration dialog is shown the first time
[KLAROS-662] - The single test run report has no header labels anymore
[KLAROS-652] - The calculated execution time of the manual test runner is wrong.
[KLAROS-650] - The properties of the dashboard reports are resetted when the active project has been changed
[KLAROS-645] - The content repository saves a file via its name.
[KLAROS-644] - Exception migrating Revision 2.0 database to revision 2.5
[KLAROS-641] - Klaros tries to migrate the database if the current revision is lower than the active database revision.
[KLAROS-640] - Unable to recreate a deleted user
[KLAROS-382] - Exporting and importing changes the ids of the objects
[KLAROS-368] - Business Code range for test results is too small
[KLAROS-671] - The Project selector should not be available when the error page is shown
[KLAROS-669] - Checking of the Applikation URL should only be allowed if an URL has been specified
[KLAROS-664] - Prevent the flickering of the dashboard if a property of a report is changed
[KLAROS-660] - Update the tomcat distribution to version 6.0.24
[KLAROS-649] - When creating a report document the browser shows the language instead of a report description in the tab title
[KLAROS-576] - Provide the ability to abort a non-finished test run
[KLAROS-546] - The execute test plan page should warn about test plans that contain non-executable tests
Version 2.4.4 - 2010-02-03:
Version 2.4.3 - 2010-01-28:
Version 2.4.2 - 2010-01-28:
[KLAROS-656] - Exception when logged in as manager and searching for users on an empty database.
[KLAROS-654] - Out of sort memory error when refreshing databtables with revisionable objects too often
[KLAROS-639] - Mispelled RTF message properties in the default message bundle
Version 2.4.1 - 2010-01-08:
[KLAROS-638] - NullPointerException on the page to create issues if the jira project ID is wrong
[KLAROS-632] - Description and summary are not rendered in the single test run report
[KLAROS-630] - The Project selection and project maintain pages still allow to filter after the JIRA ID
[KLAROS-629] - PDF icon changes to XML icon on the Test Run History Report page
[KLAROS-623] - The tooltip for the assign test cases to a test plan is not correct anymore
[KLAROS-636] - Add the possiblity to repair the database after a crash
[KLAROS-635] - Increase the business code length for test case results, test plan results and test runs
[KLAROS-378] - Imprecise error message when unable to start a test case/test run
Version 2.4.0 - 2009-12-07:
New Features:
[KLAROS-586] - Support the assignment of test plans to SUTs
[KLAROS-585] - Allow the cloning of test plans
[KLAROS-531] - support Trac as a issue management system alternative
[KLAROS-616] - The validate URL button has no effect if the loglevel is set to high.
[KLAROS-615] - The validate URL button in the configuration of issue management systems does accept too much urls.
[KLAROS-611] - Not closing the Autoupdater thread prevents proper tomcat shutdown
[KLAROS-603] - The dropdown fields on the test case details pages are not aligned with the other input fields
[KLAROS-601] - Nullpointer Exeption when searching for an empty dropdown field
[KLAROS-598] - The username cannot be edited.
[KLAROS-589] - error pages broken, if user is not logged in
[KLAROS-588] - When the selected project is deleted, switching to the default project does not work correctly.
[KLAROS-583] - unable to log in after changing admins username
[KLAROS-555] - The Continue Button does not vanish after test continuation completion
[KLAROS-613] - Preallocate the description and environment field with the information of the test run
[KLAROS-605] - Make the SUT column in the maintain test plans overview page editable.
[KLAROS-582] - Put klaros-favicon into installed tomcat
[KLAROS-578] - The continue test run data table should show the number of already executed test cases
[KLAROS-560] - Remove the unnecessary redraws and cache the graphics on the project dashboard page
[KLAROS-521] - Explain the error message for missing JAVA_HOME JRE_HOME in the manual
Version 2.3.3 - 2009-11-16:
New Features:
Version 2.3.2 - 2009-10-30:
Version 2.3.1 - 2009-10-23:
Version 2.3.0 - 2009-10-16:
New Features:
Version 2.2.2 - 2009-10-07:
Version 2.2.1 - 2009-10-05:
Version 2.2.0 - 2009-10-02:
New Features:
Version 2.1.1 - 2009-09-10:
Version 2.1.0 - 2009-09-04:
New Features:
Version 2.0.4 - 2009-08-24:
Version 2.0.3 - 2009-08-21:
New Features:
Version 2.0.2 - 2009-08-19:
Version 2.0.1 - 2009-08-12:
Version 2.0.0 - 2009-08-11:
New Features:
67657 Kaiserslautern
Europaallee 10
Germany
Web: http://www.verit.de/
E-Mail: support@verit.de
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
0 (0 Votes)
