Klaros-Testmanagement version 2.2.2 released
Release Notes for Klaros-Testmanagement version 2.2.2:
development projects.
manually executed test cases.
Version 2.2.2 - 2009-10-07:
Version 2.2.1 - 2009-10-05:
Version 2.2.0 - 2009-10-02:
New Features:
Version 2.1.1 - 2009-09-10:
Version 2.1.0 - 2009-09-04:
New Features:
Version 2.0.4 - 2009-08-24:
Version 2.0.3 - 2009-08-21:
New Features:
Version 2.0.2 - 2009-08-19:
Version 2.0.1 - 2009-08-12:
Version 2.0.0 - 2009-08-11:
New Features:
Version 1.11.0 - 2009-05-29:
New Features:
Version 1.10.0 - 2009-05-11:
New Features:
Version 1.9.0 - 2009-04-24:
New Features:
Version 1.8.0 - 2009-04-17:
New Features:
Version 1.7.0 - 2009-04-03:
New Features:
Version 1.6.0 - 2009-03-27:
New Features:
Version 1.5.0 - 2009-03-20:
New Features:
Version 1.4.0 - 2009-03-13:
New Features:
Version 1.3.0 - 2009-03-06:
Version 1.2.0 - 2009-02-27:
New Features:
67657 Kaiserslautern
Europaallee 10
Germany
Web: http://www.verit.de/
E-Mail: support@verit.de
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
0 (0 Votes)
